Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Refrigitator The front frame of the refrigitator gets hot,
  • Letloret Sep 08, 2008
    The front frame of the freezer is hot!
    any one knows why?
    can you please tell me why.
    thanks
  • Letloret Sep 19, 2008
    I lower the switch and still verry hot, any other solution?
    Genius:
  • 1,122 Answers
This is called the oder loop behind the frame that keeps it from sweating,it is normal,you have a switch inside that controls it,mike
Posted on Sep 12, 2008
Turn on my refrigitator
check ur cold control thermostat. ur defrost teriminator.
Jan 05, 2015 | Samsung RS2630SH Side by Side Refrigerator
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
Why does the front frame get real hot aroune top and bottom doors?
In some units the condenser coils run inside the outer walls of the fridge and this area can get warm. If its really hot check the visible coils at the rear and underneath the unit they may be badly clogged with dust, which cause the rest of the system to run much hotter since the airflow to the lower ones is blocked off. Make sure you clean all visible coils at least every 6 months. This will also cut down on the energy use.
Aug 08, 2014 | Frigidaire Refrigerators
Boston acoustics repair
How did debris get into your speaker?
You might try taking the woofer out by unscrewing all the screws that are holding it in from the front.
As for the grill repair? Are you handy with a hot glue gun and stapler?
Try stretching the fabric over the speaker frame and securing it with hot glue and/or staples. If you use a stapler, get one that fires flat staples not the rounded ones.
If the fabric is torn, find speaker fabric that is "acoustically transparent" commonly available from many sources in many fashionable colors.
you will have to remove the existing speaker fabric without damaging the frame. Scrape off any adhesive residue and remove any and all staples install your fabric by stretching and gluing/stapling the new fabric over the frame.
good luck.
May 26, 2014 | Audio Players & Recorders
1985 Dodge Ram Pickup Truck The front brakes
your pressure metering valve could not be working as it should,follow you brake lines down from the master cylinder to the frame rail it is on the inside of the frame rail and the front lines and back lines come out of it,on the front of the valve there should be a small ruber boot there the boot can be removed and inside on the valve you will see a small pin that goes into the valve it should be able to be moved in and out if not it could be rusted stuck and that could cause your front brakes to not release the pressure and cause your problem,i have a 1984 that did the same thing,hope this helps you.
May 08, 2010 | 1985 Dodge Ramcharger
Whirlpool fbb36af20/2 fridge freezer frame of front fridge freezer getting hot, fan at bottom back stoped working replaced fan but when you plug in new fan it starts to work but when you fully push the fan...
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
CBR900RR-3 Fireblade - frame gets very hot - is this normal?
No big deal my older gsxr frame gets hotter than the blazes of hell.
Jul 15, 2009 | 2003 Honda CBR 954 RR Fireblade
Left front element transfering heat to frame. Top side and front of frame are very warm to touch. Should I refrain from using that element until it can be check? Is there a danger of electrical fir
There is usually a door seal around the oven door if its gone or out of place this is most likely the problem. 1 other thing is that Insulation can be moved around (not meaning to offend just stating facts), insulation can be moved around by rodents, or if it happened to get wet it could shrink.
If either of these help you undersatnd and find your problem please rtate me as high as you can. Thank you for using fix ya.
Apr 28, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
83 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
