Question about Sony BDP-S300 Blu-Ray Disc Player
Sony Blu Ray model BDPBX1
We made a mistake when setting up, now screen is blank and we can't get back to the factory settings.
To set resolution back to factory setting hold down stop button for 10 seconds.
Posted on Sep 08, 2008
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
Lg dv532 blank screen with sound, presssed remote setup by mistake, pls help
Try to power the unit off and then unplug it for a while to set if it will reset itself.
Apr 23, 2012 | LG Televison & Video
Connection status cannot be confirmed the service requested was not found the server returned with the following reference code 300 on all blu ray options
I have sony bluray disc player S370 I went to set up scrolled down to resetting selected "reset to factory default settings" scrolled down and selected "system settings" and selected "start" turned off the dvd player waited about 5 seconds and turned it back on. Choose netflix, which is what I was having trouble with in the first place, and it connected. I haven't tried other internet connections through the system, however, if this is truly a sony server issue, it should correct any internet connection issue you may be having.
Sep 09, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I finally got my memorex blu-ray player set up with the tv and went on to get on netflix which Im a member and I think I need an activation code for the player, the only thing netflix could give me was...
I believe that when you set up your netflix account on the actual blueray player, it will give you a code that you need to register with netflix. go into the settings on your blu ray player and set up your netflix account. if you've already done this and didn't write down the code, reset your blu ray player back to factory default and start over. hope this helped
Mar 01, 2011 | Televison & Video
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
No Display
If your resolution on your TV isn't capable of 1080p it will not show anything on screen. You should set the Blu-ray player to max resolution of your tv.
Hope this helps.
May 27, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Dec 22, 2007 | Pioneer VSX-94TXH
Problem with wharfedale dvd player
press clear/Add twice and number 5, it has to be in monitor mode
Nov 22, 2007 | Wharfedale DVD-M3 DVD Player
Sony BDP-S300 Blu-Ray Disc Player Logo
313 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
