Question about Ovens
Smeg oven model SA708X--Clock faulty
Electronic clock is faulty, had to bypass to get oven working. What could be wrong with clock. Is this a common problem with this type of oven.
  • gazmanwa Mar 20, 2009
    how do you by pass the clock
  • Anonymous Mar 17, 2014
    907464 euro oven clock is faulty
  • 70 Answers
Hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jun 22, 2012 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Feb 23, 2011 | Stoves Ovens
My D61 e delongi cooker will not work the oven at all ,the cook top is fine
Most common oven problems are;
Faulty oven element - check continuity with meter - if faulty replace;
Burnt wiring at the oven element terminals - visual check - if faulty repair;
Electronic clock/timer on auto. - clock timer must be on manual for manual oven operation.
Feb 16, 2011 | Ovens
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg Oven digital clocks
two wires drive the clock itself so trace which these are by looking at the track on the card. join the other two. there may be linking across as well.is it a single oven?
Jul 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Not functioning
clock can be bypassed. you will have to get at the clock connections though.
you will see a recangular box on the clock pcb which is in fact a relay. next to it are two connections with fairly heavy wiregoing to them. join these together and the clock is then bypassed. you can get female to 2-male connectors which are very convenient for doing this. i must have bypassed hundreds of clocks over time
Jun 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
778 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
