Question about Philips 42PF9630A 42 in. Plasma Television
Philips Plasma Black Stripe
Our Philips Plasma 42" has just developed a 3" black stripe, right of centre. From the FixYa postings it does not sound good and it does appear to be a common problem.
What can be done?
  • hansito Sep 19, 2008
    Same stripe and it wont go away. Is there a solution that doesnt involve replacing the whole panel?
  • hlnk3 May 04, 2009
    Black and white stripes about 3"-5" width in the from near midddle and left of the screen. Did anyone have the screen successfully fixed ?
    Thanks,
Around the screen there are ribbons with driver chips on them, these ribbons generally have around 300 connections which are bonded to the glass, when the chips fail on the ribbon there's no drive on screen leaving a black bar. Usually the screen would be replaced by the manufacturer within the warranty period, I have the machine that can re-bond another ribbon which can work on around 80% of the screens and could save you money. You can email me on rajkp67@yahoo.com if you need my address to bring your plasma over.
Posted on Oct 14, 2008
We have the same problem with out TV. Apparently the problem is the drivers.
Posted on Sep 22, 2008
42 Plasma LG TV that presents a 2 inches black vertical stripe
may be worth getting repiared,sounds like decoder video o/p.or line o/p stage.
Jul 30, 2009 | LG 42PC3D 42 in. Plasma Television
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
318 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
