Question about Panasonic Microwave Ovens
The interior light has blown in my Panasonic microwave. There is a plastic cover inside - is this the way in or do I have to unscrew the back of the unit
  • Panasonic Master
  • 9,098 Answers
It depends on the model number.
If there's only one cover inside, it is the waveguide cover, not the light cover.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How do i change the interior light inside my Panasonic The Genius Prestige model #NN-SD291W
The bulb, which may be replaceable, is accessed by taking the cover off the machine.
God bless your efforts.
Jul 28, 2017 | Panasonic Microwave Ovens
The plastic round ceiling cover in my OTR Samsung smh9187 has always been missing the locking clip/screw and has gotten loose but was easily turn back in position, yesterday it came loose and fell down ,...
Microwave ovens have special coatings on some of the interior panels and covers to prevent arcing. If there was arcing then that can cause the main component in the oven to fail and be expensive to replace. IF you do keep it you have find what is arcing and repair that.
Dec 27, 2014 | Microwave Ovens
I need a new light inside my microwave oven. Can someone come out and do that for me?
Sorry- no house calls! LOL!
It is easy enough though- almost all microwaves have a plastic cover over the light that either snaps in or uses two screws to hold it in. Pop the cover, and screw in a new bulb (generally they are just called "appliance bulbs" at Home Depot, etc..) - then you will be good to go!
Jun 09, 2011 | Panasonic PHPNNSN667W Microwave Oven
How do you change the light bulb in a JVM 1440?
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | GE JVM1440 Microwave Oven
How do yo change a blown light on a NN-T774SF micro wave
just disconnect from the power and take out the screws from the cover around and you will see a plastic color white then remove a screw from them and you find the bulb replace and return all parts back
Apr 01, 2011 | Panasonic NN-T774SF Microwave Oven
Over the range microwaveoven worked flawlessly then bang it quit.it looks like its been unpluged but no. I tested the electrica outlet and ther is power. Is there a reset button within the microwave that...
you have a blown fuse.unplug the microwave. remove the vent by unscrewing the 2 screws holding it in place. gently pull vent grill forward to remove. open the door, and remove the screw holding the control panel in place. remove the metal plate being held in place by that screw. inside that panel is your blown fuse. remove the fuse and replace. reassemble the microwave. plug it back in.
Feb 08, 2011 | Panasonic Microwave Ovens
Replace the bulb in Panasonic microvave Model nn s 768ba
Hi all,
I have just replaced the bulb in my Panasonic NNA873 Dimension 4.
Please be careful,although it was an easy job, there is a capacitor inside which stores heavy loads of power and will release the electricity into you if you touch it!
YOU CANNOT REPLACE THE BULB FROM INSIDE THE MICROWAVE....... DO NOT REMOVE THE CARDBOARD-STYLE COVERING WHICH IS ATTACHED WITH ONE SCREW INSIDE THE MICROWAVE ON THE RIGHT.
To replace bulb will take 5 minutes.
UNPLUG microwave. Remove the outer cover by unscrewing about 6 screws (ordinary phillips) don't lose them into the workings.......
Bulb is located on the right side, nearer to the front. You cannot see the glass of the bulb, only the black plastic end piece, as the bulb sits upside down and vertically. Best if you check out what a T170 looks like on the internet, then you will know what you are looking for. For my Panasonic I needed a T170 (but be careful, they have different ends, some are straight, some right angled - mine was right angled - check before you buy and no, I don't think you can get them from any ordinary supermarket etc!!). Do not touch the bulb when replacing as the oil on your fingers will shorten its life.
Old bulb can be removed by taking out one screw and then pulling off the connectors - there is a little tab to push down to ease them off.
Then simply replace bulb!
When putting cover back on make sure all the tabs on top and sides go inside not outside casing.
Good luck. This is an easy job, just don't poke around anywhere else.
Oct 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
