Question about Behringer Pmp3000 16 Channel Audio Mixer
10w 22rj wire wound resistor - Behringer Pmp3000 16 Channel Audio Mixer
  • Behringer Master
  • 5,603 Answers
When thosse resistors (precharrging of main input filters) burn up there is major damage. The IGBT's are usually gone... replace with APT28GA60BD15... the switching regulator IR2153 is gone... one or more of the 2SA1020-Y and the 2SC2655-Y gate drivers are gone. One or both of the DL4148 speedup diodes for the IGBT gate drives will be gone. The Wirewound ceramic resistors either 10 or 22 ohm 10 watt radials... Use:
http://www.mouser.com/ProductDetail/Ohmite/TWW10J20RE/?qs=GcOFt9%2fAxQHny%252b35G6iehQ%3d%3d
This is 20 ohms, however Behringer uses from 10 to 22 ohms in these units... 20 works fine as does 10 ohms. If you have toruble getting schematic let me know.
Posted on Aug 22, 2011
  • stuart urquhart Nov 15, 2011
    Hi, have you any rough idea what it would cost to repair a problem like that? I think i have this same problem on the europower pmp5000. it also took one of my speakers out, could it be the same fault? Thanks
  • Fred Yearian Nov 16, 2011
    Sometimes only the power amp (one side goes) and power supply survives. If leds are on supply is OK... if all dark then supply is gone as well. There is a Triac protection circuit that SHOULD protect your speakers... doesn't always work. A regular shop will replace the HCA2400 power amp module and might replace the power module as well. The HCA2400 are $155 from FullCompass.com... don't know what the power supply cost however. There is around $45 of parts that fry with the failure if both are gone and a lot of labor, especially to restore the HCA2400 which often arcs between layers of the multilayer circuit board. Most shops won't attempt a repair of the HCA2400... I have done a few for my own use... it is PAINFUL work believe me. You can figure about 4 hours shop labor minimum.
SOURCE:
Need to find location for a 1972 mercedes 280 sel
I think the Bosch W230T30 were stock. new Bosch # is W5d1.
If you've updated the original plug wires to a non-resistor type, you may need a resistor type plug instead of the stock plug.
Oct 22, 2014 | Core New Core One Bullet Spark Plug...
Guitar tuning peg seems like it might be broken it will tighten the string to a certain point then it clicks and its completely loose again...I'm new to guitar so I don't know If this is normal
It seems like you wound and tightened your string on the tuning peg loosley. Try wounding the string at least 4-5 times around the peg after you pass the wire though it and then after winding pass it through the hole again. Tighten well.
If that doesn't work your peg might be broken, but looking at it on the video seems that it's not, even though you can't see it clearly.
Try tightening the screws on the peg, since there's a lot of tension on the highest string and it might cause the peg to click back because the tension is too high and it's loose.
Jan 30, 2013 | Music
I have a burnt resistor on a V55hd head. It is near one of the powertubes. Need to know how to calculate the value for replacement, and know if there is some sort of resistor type that will be more heat...
Usually the amplifier will have "symmetry" and there will be matching resistors near the other power tubes that you can get the value from. This is PROBABLY a screen resistor for the tube and values are often around 470 ohms or so but I could not find a schematic. These USUALLY don't fail unless a tube has shorted. Heat sinks are NOT used. The best resistors for the purpose are "wire wound" ones and of a suitable wattage rating. Sometimes we put ceramic beads on the leads to raise the resistors off the board to allow air circulation. Occasionally solder will break and the arcing at the leads adds to the heat. If you trace where the resistor goes by pin number of the tube and the type of the tube that would help me to help you... trace a matching tube to the same pin and you will likely find a matching resistor. Note that some power resistors DO change color a bit after they get hot in use, but if they char or the coating falls off that is a failure.
Aug 15, 2011 | Behringer Bugera V55HD 55W Tube Guitar Amp...
I recently broke the E string on my Ibanez 5 string bass and replaced it with a 100 guage one. The sound level is now very low, lower than both adjacent strings. I have tried lowering the bridge, but this ...
Replace it with the same size as the original and the original type. The 100 sounds right for the E. Make sure it is the SAME type string as there are non magnetic for some guitars and if you have magnetic pickups the bronze types won't work. There are also round wound, flat wound and some are flattened on one side. You need to make sure the replacement is exact type. Take sample of old to show store clerk.
May 24, 2011 | Ibanez Srx505 5 String Srx Bass
My Fender Vintage Pickups came with a Capacitor AND a Resistor. Where do they go in the wiring of the pickups??
http://i296.photobucket.com/albums/mm169/Link47UD/DSCN0328.jpg
this shows the proper location of the two different caps and the resister, but the rest of the wiring should be stock Strat wiring (the owner of the guitar in this pic says there is a wiring problem- so don't necessarily follow everything...but the caps and resister are correct).
Feb 24, 2011 | Fender Vintage Noiseless Strat NeckMiddle...
The RW5W in the R-15 spot on the circuit board of my marshall mg100dfx amp is loose and needs to be repaired. looks like i have to pretty much disconnect all front knobs and most wire connections, to pull...
Yes, they are a pain to have to remove the knobs etc. to get the board out.
If the resistor has burned or browned the board, resoldering may not be good enough as the traces to the pads and the pad MAY have unbonded from the board. In this case you may need to install eyelets to get adequate support for the resistor. The other method is to install "turret" terminals and attach the resistor to those... the turret terminals kind of rivet into the board to create a secure mechanical connection.
Sep 14, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Loud crack when turning unit on, blows main fuse no lights come on.. bottom of power supply black and signs of burn...
DO NOT REPLACE THE FUSE !!! You will do more damage.
I just repaired one of these. A small ceramic surface mounted cap very near where the +/- 85 volt connectors plug onto the board blew up.
This left a sputtered mess on the insulating material at the right rear corner of the power supply.
The net parts list of parts I had to replace:
1. Main IGBT transistors on heat sinks. You have to remove the heat sinks to get at the mounting screws. 1MBK50D or equivalent. I used DigKey part APT28GA60BD15
2. One 1N4148 surface mount diode that is for gate drive speedup. D24 and D25. (don't remember which one was shorted)
3. All four driver transistors for the gate of the IGBT's. @ each 2SA1020 (PNP) and 2SC2655 (NPN). These are tall TO92-like transistors and I believe that at least one of these I had to get from Mouser.
4. Transistor T9, suface mount BC856B (PNP)
5. Replaced all four surface mount caps, one had exploded.
C50, C51,C54,C56. Replace with 0.01mfd/200 Volt 1206 style surface mount caps Digikey 478-1511-6
6.Replaced ceramic wire wound 10 Watt stand up resistors that were blown open. Replaced with 20 ohm design change. These slowly charge the main input filter caps and when supply is stable, a relay shorts them out. If you have replaced the fuse, you LIKELY blew them out. Original value was 10 ohms on some units. This was a Mouser part. 280-PRM10-20-RC
7. The 2153 switching reg chip IC1. This chip shorts. It is made by International Rectifier and I believe the full number is something like IRF2153. I had these in stock and not sure of which source I had procured them from... It was from one or the other.
Lots of destruction and one really needs a desoldering station to work this. Removal of the blown IGBT's is especially tough. All solder must be removed from the transistor leads AND the thermistor on one of the heat sinks. Once you have verified the leads are loose, one has to rock the heat sinks to get the tabs free. The tabs are NOT soldered! Be careful when restoring to get the thermistor leads started in their holes.
Note: ALL these repair parts were procured from DigiKey.com and Mouser.com. Neither of these places had all, I had to order from both. Mouser had the ceramic resistors.
When restarting this, leave outputs disconnected until it is running again. USE a series 75 watt light bulb in the 120 volt input. ONLY work on the unit using an isolation transformer as a large portion of this is connected right to the power line.
There is a small 15 volt switching supply that comes on first that runs the relay to short out the inrush limiting resistors. With the 2153 shorted as usual, this auxilary supply can't reach voltage enough to turn on the relay. The power for this is supplied through the ceramic resistors.
May 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
Light indicator is on
Try changing the battery, if it doesn't help, some possibilities are:
- dirty contacts or a broken wire on the footswitch
- a broken wire from the distortion output to the output plug
- a broken wire elsewhere in the unit (e.g. potentiometers or rotary controllers)
- a bad input / output level or other potentiometer or rotary controller
- a burnt out component (a bit unlikely, but possible, and it could be anything)
- a bad connector contact inside the unit
- a bad pin solder contact on ANY of the components inside the unit (wires, connectors, switches, jack plugs, resistors,variable resistors, trimmers, diodes, capacitors, transistors, ICs, etc.)
Broken wires / badly soldered pins need to be resoldered, but if there is damage to any of the components, they wil probably need to be replaced.
I hope you can find out what it is.
regards
3rq8 (Triarcuate)
Jul 26, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Behringer Pmp3000 16 Channel Audio Mixer Logo
285 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
