Question about HP LaserJet P2015 Printer
Printer status offline
I use hp laserjet p2015 and i using network printer..my problem is printer status at server is offline..but i try to ping ip its work..i use windows server 2003 r2
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
There is a firmware update for this problem. Check out this link:
http://www.hp.com/pond/firmware/hidden/P2015FWUpg20080312.html
Posted on Apr 07, 2009
I have hp lj 4100n printer in my office. this printer is been used for backup. today we saw an offline problem. we just did basic thing like right click on printer icon make seclect printer on line and...
Thank you for contacting FixYa with your printer inquiry.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - A Printer Reports Being Offline or Out of Paper A printer using the HP Standard TCP/IP Port reports being offline or out of paper, even though the printer can be pinged, can display the embedded Web server, and is not out of paper.
  1. Open the Printers or Printers and Faxes folder.
  2. Open the Properties of the printer and the Ports tab.
  3. Click Configure Port .
    This is the most common cause. Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Jan 18, 2011 | HP LaserJet 4100 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
The printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
May 10, 2010 | HP LaserJet P2015dn Printer
In have an HP4P LaserJet printer that normally works well with Windows 7. Once in a while the printer doesn't print-any suggestions?
is that printer connected directly to the printer if so check if printer online or offline status. or trace if the printer problem is in printer itself?
Mar 31, 2010 | HP LaserJet P2015 Printer
I have 2 HP LaserJet P2015 with the same IP Address and have tried re-setting one back to factory settings by holding down the go and cancel buttons when switching the printer on, but it is still keeping...
Hi Sue_sams
If you know the IP address of the printer then you should be able to do a reset via it's internal GUI.
1. Make a note of the printers IP (if you print a status page by holding GO for 5 seconds it should give you this).
2. Open up Internet Explorer. Where you would normally type www. type the ip address of the printer (make sure there is nothing else in front) and hit enter.
3. Click on the 'Networking Tab' and give the printer the IP that you want it to have.
For further help a PDF of the manual can be found here. Details of the Embedded Web Server are on page 54.
Hope this helps and good luck!
Scott
Feb 01, 2010 | HP LaserJet P2015dn Printer
HP Laserjet 5000 moved and now says offline
Please verify the workstation (or server) is not set to "use printer offline", I also suggest trying to ping the ip address of the printer or trying to access the webinterface of the printer by going to printers ip address in a web browser.
Please let me know if this fixes your problem or if I can be of further assistance. Thank you.
Sep 18, 2009 | HP LaserJet 5000n Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Mar 05, 2008 | Trendware TRENDnet TE100-P1U Print Server
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
HP LaserJet P2015 Printer Logo
3,111 people viewed this question
Ben Johnson
