Question about NEC Dterm DTP 32D-1 Corded Phone
Do not disturb
Can you put a do not distrub function on when required
  • 35 Answers
If DND is Programmed on your phone
Posted on Apr 19, 2009
  • Noel Coward
    Noel Coward Apr 19, 2009
    do you have a DND button
Put new distruber in my 1975 ford 351 m I can get
Backfiring through the carb is a timing problem. I would bring it back up to top dead center and reinstall the distributer. Also double check your firing order on your plug wires.
Sep 11, 2013 | Cars & Trucks
DND ALL on the screen
this a problem that the person handling the extension number has putting Dont disturb.see how to your user manual
God bless you
Oct 09, 2012 | NEC DTL24D1BK Phone
How to tune up 96 chevy corsica
You will need a 3/8" drive ratchet with a 5/8" spark plug socket. There is no distributor on these engines so you won't require a dist. cap. You will want to change spark plugs, ignition wires, air filter, fuel filter and pcv valve. There are no other adjustments.
Sep 14, 2012 | 1996 Chevrolet Corsica
Switch off kc910
This phone has an AIRPLANE mode. This means that all functions that require communications are turned off, so you cant receive calls or messages, but can listen to music, review stored messages and see stored pics.
Apr 05, 2012 | LG KC910 Renoir Cell Phone
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
Mitel sx 50.. How to unlock room to take it off from do not distrub(in room phone)? Thank you so much
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
Oct 13, 2010 | Mitel 9104-001-000 Power Supply SX-50...
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
Mobile is glowing for every incoming message/incoming call
You haven't said about your mobile model.
Moreover, these blinking will come when you keep your mobile in silent/vibrating mode.
Anyways, if you are getting disturbed by the blinking of the display in the nights, then keep your mobile upside down.
Feb 07, 2009 | Nokia N72 Cellular Phone
Ge cordless phone model # 28111ee2-a is on do not distrub
There is a do not disturb button on the base of your phone - if it's red it's on. Press it to turn it off. It is on the main base and works for both headsets.
Dec 07, 2008 | GE 28112EE2 Cordless Phone
Ignition timing
put a mark on the timing notch on the harmonic balancer, ( the large puuuley at the bottom of the engine that connects to the crank shaft ). remove your # 1 spark plug and put a long screw driver in the cylinder, turn the engine over by hand until the timing mark is at the correct timing mark and the # 1 cylinder is at top dead center ( at the top ). then set the distributor back in the engine wth the rotor pointing to the # 1 cylinder this will bring you very close to where you need to be. you may end up being a tooth out or you may be able to finish pinpointing the timing with a timing lite by just turning the distributor.
Oct 12, 2008 | 1996 GMC Sierra
NEC Dterm DTP 32D-1 Corded Phone Logo
154 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
