Question about Boss 634UA CD Player
BOSS 634UA head unit bazirk
Ok, I have had this head unit for about 9 months. It has worked ok so far. Today however, I put a cd in and after playing the cd for a few minutes the head unit started flipping through all the preamp settings on its own. It then started turning the subwoofer on and off. Then non of the keys would respond to pushing them. I have tried resetting, reloading, removing and reattaching the face plate and nothing will get it to stop. it does it using tuner/usb/aux/cd all the same. Please help, I am very frustrated!!
3 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: setting the clock on my boss 634UA
Hi Tru Infini,
Gopt it for you. The manual is at this URL. http://www.bossaudio.com/support/index.php?_m=downloads&_a=downloadfile&downloaditemid=285
Picture below tell you how to set your clock its Easy.
Posted on Nov 20, 2007
kenw392
  • 2226 Answers
SOURCE: i hooked my subwoofers up to my radio and they
use the blue/white wire ( amp remote turn on) instead of the blue (antenna remote turn on).
Posted on Nov 15, 2010
I have a BOSS BV760B and the unit will not except a cd. Everytime I put a CD in the unit it will only go in so far
The player loading mechanism has failed, this is common, due to the low cost of these players they are not repaired just replaced except under warranty.
Jan 25, 2017 | Boss Car Audio & Video
I removed my PU 2471A head unit and Blaupunkt IDC-A09 changer from my Peugeot car as both had minor faults caused by my son putting objects into cd slots.Prior to this both units worked perfectly in...
The head unit needs reprogramming with planet to accept the CD changer....... a main dealer or any good local garage should be able to help you with the software needed.
May 27, 2017 | Blaupunkt IDC-A09 5-Disc CD Changer
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
I have not played my electric guitar for months now there is no sound coming through the amp, the amp works ok
probably have active pickups on the guitar.
if there's a plate on the back, get a small phillips screwdriver, take the plate off, and put a new 9 volt battery in.
Oct 14, 2008 | Washburn Amplifiers: 25 WATT Guitar...
Adding aftermarket audio to factory amp.
yes it will kill your batery u need aremote turn on man dont messa round with out one
Feb 03, 2008 | Car Audio & Video
Kd-g322 error code query
I unpluged all the wires for one more time and it works again!!!
I think the problem is that one or some wires are damaged because they are pressed between the unit and its case. I also shaked them up and down and for now, it is ok. Try it!!
If this works for more than one day, I' ll let you know...
Jan 03, 2008 | Car Audio & Video
USB stop working
Use the Aux in cable with an ipod. Works great so far......
Dec 20, 2007 | Boss 634UA CD Player
Rf not being picked by my fm car radio
I kept the cd changer idle for long time now it is not reading or ever the spindle motor is working pleas help me
Dec 03, 2007 | JVC CH-X1100RF 12-Disc CD Changer
Setting the clock on my boss 634UA
Hi Tru Infini,
Nov 20, 2007 | Boss 634UA CD Player
Boss 634UA CD Player Logo
46 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
