Question about Tefal Avante Deluxe 4 Slice Toaster
I have a 4 slive tefal deluxe toaster which has stopped working
Often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Posted on Sep 18, 2008
Where can I get operating instructions for the Tefal 5327-16 four slice electric toaster?
Hi there.
I have seen an Avante Deluxe 4-Slice Toaster Owner's Manual at
You can download this if it matches the model of your toaster.
Jul 18, 2011 | Kitchen Appliances - Others
Can you email the user manual for tefal toaster , please.
dont have one,but you may be able to find one,
Oct 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
How to operate it
web search -tefal avanti toaster operating instructions- 7th site down to download instructions
Wont stay down
At the moment I am looking for the problem in m,y Tefal. The biggest problem seems to be sorting out how to pull it apart. I have sfound that the whole carriage must be pulled out the back of the toaster. About 10 T10 screws to be removed from the base then there are are a couple more philips screws to remove after the back is off, then the handles that you press down to allow the bread to drop mus t be released. There are plastic pieces that hold in the metal tip on the handles. They are located inside the body and are accessewd from the slot that the handle moves in. I haven't yet located the release clips for the high lift handles. Once I have found them I may be able to access the mechanisms. If this doesn't help enough then please ask for more information as I shall have found my way inside by then
Jul 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Clean out bottom
Hi .. turn the toaster upside down. There should be an access door there to allow you to clean out the bottom of the toaster.
May 03, 2010 | Tefal Avante Deluxe 2 Slice Toaster
Can you email the user manual for tefal toaster avanti deluxe for me to download please
Hello Val,
Here's the link directly to Tefal's site where you can select the exact toaster manual from the list provided. I wasn't sure of the exact model, since Tefal has two (2) Avante Deluxe model toasters available (both a 2 and 4 slice version) and sometimes the Fixya site only has a limited selection for certain products for users to request assistance with.
In any case, they are all on the page at the link below. Simply click and you'll get a free manual that you can save or print out for your use and future reference.
If it doesn't come up, simply select "toasters" from the pull down window on the screen and hit "go"
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to search the web for them.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Lever to lower toast has snapped off just inside the toaster casing. It is plastic and cannot be reattached
Hello Sue, I've attempted to locate replacement parts for for Tefal Avante toaster, but there doesn't appear to be a broad source for these, which troubles me as I've got the same toaster and use it everyday.
I did locate the Tefal customer support/service contact that should be able to provide you with either a local authorized service location or provide you with the replacement parts you need to get it working again.
You can call Tefal directly at 1--800-395-8325 from 8:00 AM to 5:00 PM Monday thru Friday, EST
Here's a link to the contact page, in case you prefer to send an email instead.
With luck, Tefal will be able to assist you in getting your toaster working like new soon.
Nov 23, 2009 | Tefal Avante Deluxe 2 Slice Toaster
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Tefal Avante Deluxe 4 Slice Toaster Logo
321 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
