Question about Hotpoint Aquarius WF000 Front Load Washer
Putting a new belt on
Strecting the new belt on to the cogs
    Novelist:
  • 166 Answers
Peace Friend,
ngafm At your service!
You should not have to stretch the belt to get it on.
You should be able to release the tension and slip it on! if you can not and have to stretch it on, you are missing some step.
And may damage the belt or machine!
My advice do not force it!
Better call service or you may be repairing it again or the belt again soon!
I like my machines to run fine and last long! proper is better!
I hate to spend good money twice. Don't you?
Bless You,
ngafm
Please give me a good rating for my fine money saving advise. before you sign off..
Thank You
Posted on Sep 10, 2008
I have a beko washing machine that needs the belt replacing. We cannot get it back on. Any suggestions
Posted on Oct 10, 2008
  • speaky Oct 10, 2008
    Have got the belt on but it keeps coming off!!!!!!!!
Help put on the belt
Posted on Dec 01, 2008
How to fit cogged belt to metabo kgs 303 plus
check to see if there is a plate on the end of the cog that keeps the belt on
if so remove those plates and then slide the new belt on both cogs evenly
refit the plates
Oct 10, 2015 | Cars & Trucks
How do you replace belt on brush?
Remove the plate on the bottom front of the vacuum by turning the plastic knobs on the plate with a nickel or screwdriver. Then pull out the brush bar and slide the belt over the brush bar and align it with the "cogged" portion of the brush bar.
Slide the belt and brush bar up into the vacuum and over the small cog on the motor. You'll need to pull back the idler pulley which is the smooth metal cylinder next to the cog on the motor. Once everything is lined up push the brush bar into its slots and reinstall the bottom plastic plate onto the vacuum. Everything should be in good working order now!
May 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Broken belt how to fix i have a belt
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Shampooer
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to check the location of the pump belt?
Jun 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
How do you replace the belt? I took off the door and there seems to be no easy way to get it over the lower red wheel.
Mar 26, 2008 | Vacuums
Bissell Proheat Carpet Cleaner
First remove the some cover on the lfet side that is on top, then turn unit over, remove the red lock plate, has 1 screw, pull it out, then you can pull the end cap out, remove it, the cogged belt is there. If while you have the brush roll off, the pump belt can be replaced also. REmove old belt, put new belt over the bigger round part of the pump pully, feed it thru opening, then from the top, grap it and stretch it over the motor shaft. Then put the cogged belt on and reinstall the brush roll and the red lock.
Jan 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat
The easiest way is remove the belt cover on the top housing, turn unit over, on the belt side remove the red plastic lock, one screw, then you can pull the brush roll cap out, take it off, then you can get to the cogged belt, look further in and you can get to the pump belt. You didn't which belt you want to change, if it is the cogged belt, check the end on=f the pump that the belt goes on, if the cogs are gone, you will have to replace the pump, if they are there, then just replace the belt and put back together.
Jan 07, 2008 | Vacuums
Bissell shampoo
I am assuming this had a flat and a cogged belt, if not then provide the model number.
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Nov 14, 2007 | Vacuums
Power brush on Green Bissell power steamer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Sep 24, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hotpoint Aquarius WF000 Front Load Washer Logo
280 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
