Question about Frymaster Dean Kitchen Appliances - Others
Frymaster fryer mj45eusd
The fryer comes on but will not shut off at the right temperature we put in a new thermostat but it did not help
    Problem Solver:
  • 7 Answers
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Posted on Sep 18, 2009
Why fryer heat up and than the gas shut off
If the pilot light goes off too, then the thermocouple is defective. Otherwise its the thermostat or heat overload protector trips due to excessive temperatures.
May 22, 2014 | Frymaster Dean H14 Deep Fryer
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
I have an older propane fryer tha will not cut off when desired temp is met. It holds about 2 to 2.5 gallons of oil. I think it is called a table top model. Any solutions?
Sounds like your thermostat is not working correctly. If it doesn't shut down when you reach a desired temperature, then it could be broken.
Are you sure it's actually reaching the desired temperature? You might want to put a thermometer in your oil and read it to make sure your oil is the desired temp before you go to the trouble of replacing your thermostat. If you need a replacement thermostat, we sell them, and you can call us at 888-542-5959. We would need model, and serial if you have it in order to price this part for you.
Thanks,
Susan
Restaurant Equipment Outlet
Cincinnati, Ohio
Dec 04, 2011 | Frymaster Dean SR42G Deep Fryer
I have a frymaster gf14sd and when turned on for about 20 minutes the fryer turns off and pilot light goes out and will not restart til it cools down .
First you will need to determine what the oil temperature actually is when the fryer shuts down. The reason for the shutdown is likely the hi-limit thermostat is tripping. That could be the result of the hi-limit thermostat being faulty or the thermostat is faulty and the oil is actually too hot eg: 450F. Once this is determined, either the thermostat or the hi-limit will need to be changed. The part number for the thermostat is 807-1692 and the hi-limit is 826-1177. I know this post is late, hopefully it will help someone.
Aug 20, 2010 | Frymaster Dean 1824G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Thermostat
By e-mailing me with M3 & S# at capt_rick1912@yahoo. I would be able to get that right out to you.
captrick
Jul 14, 2009 | Frymaster Dean SR42G Deep Fryer
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
Heating problem with frymaster h14-2
I called IG Service in Denmark, who have their own technical experts, And they will now solve it.
I found them via the frymaster homepaige.
www.ig-gruppen.dk
Jan 15, 2009 | Frymaster Dean 2424G Deep Fryer
Frymaster gf 14 won't come on
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Jul 14, 2008 | Frymaster Dean FM345EETC Deep Fryer
Open Questions:
Kitchen Appliances - Others Logo
279 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
