Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100 I have a Sony KV-27FS100 TV that has no picture, but I do have sound and can change channels. The indicator LED blinks 4 times then repeats. I'm told that this is likely a problem with IC561 (TDA8172). I measured 1.1V at pin #2 of IC561 and 0 volts on pin 9 of the flyback (not sure which was pin 9, but measured the pin that the schematic said should be +15V on the flyback). I have replaced IC561 (TDA8172). Afterwards there is no difference in voltage measurement. I don't know what next to check. Should I do check some other parts? There must be power sent to IC561, so what would I check to see it is getting power? I am a hobbyist and have a DVM, and no other equipment. I do have basic knowledge, but don't know anything about convergance or other adjustments.
  • 4,234 Answers
Typically, the 4 blinks indicate a vertical defelection problem. This can be either a defective vertical IC (in thi case the TDA8172) or the supply line to that chip. Since you have already replaced the IC, we need to look for the feeder to that IC. I suspect that the original IC was infact bad and that it took out other components when it shorted. I will look up your sepcific model and list the possible parts tonight. In the meantime check any low valued resistors with the same circuit designations. In other words: if the vertical IC was IC 561, look for low valued resistors with the designations R5xx.
Update this with your findings.
Dan
Posted on Sep 08, 2008
    President:
  • 1,263 Answers
In theses set's there should be a board that has a module that the power chord plugs into this module supllies the motherboard and the componants on it. to be honest it would be best to just let a professional replace any defective chips orboards at this point because i believe it is not just one problem but several and without me beibg hands on it would be difficult to narrow it down to just a simple answer.
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Triniton WEGA KV36FV27 no sound or picture timer blinks five times pauses then repeats five blinks. Please advise what this code means in lieu of call a serviceman. Thanks--disabled senior.
in this model error 5( 5 blinks then 5 blinks) is indicating AKB, TOO LOW or ABSENT beam current. Meaning the tube has gone bad. You will need to replace the tube. I am sorry for the bad news.
hope that doesnt hurt my rating.
Mar 18, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a sony kv-27fs100 when i try to power it on it blinks 14 times after that its just 5 times over and over again what is a fix for this and if someone has a list of the placement of the componets on...
Sony Televisions have indicators like blinking lights to give you a clue what parts have failed.
In your case it could be the worst your picture tube.
Do you remember how it normally would start (blinks) and if it was lacking ant color in the picture or if it just wasn't really clear any more?
10 years was a good life without any service.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Thank you, it is fixed now.
Happy to help. Thanks for the update.
Dan
Oct 15, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega Trinitron KV-32HS20 TV
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
