Televison & Video Logo
Posted on Sep 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Sharp Stereo System Model # vz 1550c. It has a Phono, double tape deck, CD/Aux, and Tuner. Am unable to find belt to drive the turntable or the parts manual.
Anonymous
Level 3:
  • Master 1,512 Answers
  • Posted on Sep 08, 2008
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829671
Points
3938
Hi
You can get a belt from here for the turn table, looking for a manul for you now. :)
regards
Robotek
  • Anonymous Sep 08, 2008
    Not having alot of luck with a parts manual as such, if you give me a description of the part you need, I may be able to get the part number ytou need from my sources for you.
Anonymous
Level 3:
Master:
  • Master 763 Answers
Anonymous
Master
Level 3:
Master:
Answers
763
Questions
Helped
220397
Points
1990
Try to see your manual of your stereo. maybe it has a parts of what your looking for.
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
I need manuals for hooking up my fisher stereo system model ca 871 amp fm 871 tuner cr-w890 tape deck eq 867 eq can not find manuals
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
I can't get much sound from my tuner/receiver. I have tried all possible connections.
"Much" sound? What's that mean? Very low, almost silent, tinny?
"There is a switch on the bottom panel, next to the RCA cables, that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable (PHONO) input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input."
Conect my pick up with my stereo SH EH 760
Whats a pick up dual 505-2 belt drive? some kind of deck i.e turntable.if it is then plug it in the phono socket & then earth it to the ground screw to stop it humming. Failing than that u will need a mixer a small **** one will do. the same aplies plug it in the phono socket & then earth it to the ground screw come out of the MASTER or the BOOTH.out put in to the AUX or VCR in put on the HI FI....... & then If u wanted you could Then come back throu the VCR out puts into a CD or TAPE Recorder.
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
1helpful
2answers
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
6helpful
2answers
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
1helpful
2answers
TURNTABLE PROBLEM
You have a VERY nice turntable! TWO quick questions: 1) How do you define "minimal" volume? It is not NECESSARILY unusual that your turntable / receiver combination will have lower volume than your tuner, CD or DVD player. What happens when you CRANK IT UP?! Don't worry about the position of the volume control! 2)Are you changing the turntables output settings via the switch under the platter? Please post a reply and we'll go to the next step! Note: Ceramic cartridges are pretty much extinct. They were strictly low-end, low-cost, low-fidelity devices used in cheap audio systems of "yesteryear". Have you ever seen a BSR or Garrard turntable? Or your grandad's Magnavox Console Stereo? THAT'S where you'd find a ceramic cartridge!
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
