Question about Samsung NV3 Digital Camera
Memory card Samsung Nv3
Camera failing to recognize the 2g external memory card. showing the icon in the lower left corner to insert even though the card is in the slot.
  • 4 Answers
This is a common problem and I had the same issue. Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work but I would try to find someone that has used the brand and size and knows that it will work.
Posted on May 23, 2009
My camera is saying memory full with a new sd card in. why?
The Samsung NV3 can only use standard SD memory cards up to 2GB. I'm guessing that your new card is a 4GB SDHC card, which the camera is not capable of recognizing. Fortunately, 2GB SD cards are relatively inexpensive these days, and are widely available on Amazon (see this link) if your local store no longer carries them.
Oct 08, 2011 | Samsung NV3 Digital Camera
My camera always shoing memory full , i format the internal memory and format new sd card , same problem , still shoing the same , how can i fix it
Make sure that the camera is set to record to the memory card... often the internal memory will only handle a couple of pictures...
If it still shows memory full then a ribbon cable has come loose inside the camers and it is not recognizing the memory or cards...
heatman101
Apr 23, 2011 | Samsung NV3 Digital Camera
I have a samsung nv3 camerea , i added a new blank memory card but camera says memory full and cannot take pictures
It may be telling you that the internal memory is full. You must get rid of anything in there. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your new card and do the "format" thing again.
Jan 21, 2011 | Samsung NV3 Digital Camera
Hi, I have a Samsung NV3 camera, I have installed a new 4 GB memory card but it is showing memory full. Is there and internal memory on the camera that is full that requires deleting? many thanks
I've tried to download a manual for this camera to give you the most accurate answer possible, however after a few minutes of frustration I'm going to answer this sort of "off the top of my head so to speak" My first impression is that the 4GB memory card my be beyond your cameras capabilities but first try this. Have you checked the memory card to make sure it's not locked I'll include a diagram check the small circle for the correct orientation the arrow shows the lock position.
Diagram
Once you have made sure the card is unlocked install the memory card and then format the card. Formatting "programs and new card to work with the camera it has been installed into. Also Formatting should be done after each download of pictures to the computer hard drive. In this case formatting cleanse the old pictures off and programs the card once again to give optimum performance between the camera and memory card. If this still doesn't work then I suspect the 4GB card is to large for the camera "firmware and you will need to update your camera on the Samsung web site to a newer version of firmware. Sounds complicated but heck i did it so it's not all that technical. Also the memory card you are replacing may only need to be formatted to begin to work properly again (that's if you were having problems)
Jan 05, 2011 | Samsung NV3 Digital Camera
Sdhc card used in samsung nv3 it says memory full
I don't think that camera (the Samsung NV3) takes SDHC cards. The same is true of many (perhaps most) cameras that were released more than a year or two ago.
You need to use a regular SD card, which -- as you probably know -- isn't any bigger than 2G.
May 20, 2010 | Samsung NV3 Digital Camera
I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
Apr 22, 2010 | Samsung NV3 Digital Camera
Camera says memory full, even thou I have put in a brand new memory card?
With the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the card and do the same thing.
Feb 25, 2010 | Samsung NV3 Digital Camera
I already uploaded pics on my samsung nv3 but it says no image..
take the external memory card out and see if they were captured on the cameras internal memory.
Aug 02, 2008 | Samsung NV3 Digital Camera
MEMORY FULL
How many photos or videos do you have on the camera already? It probably won't store more than about 4 shots.
May 04, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
95 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
