Maxtor Basics 120GB
I have purchased the above but cannot seem to get it to work. It doesn't show anything when I plug it in and as it does not come with instructions I am at a loss of what to do now and I badly need to do a backup.
Regards Marian
Try this because the above response is talking in another language to me.
1. Completely disconnect the One Touch from the Computer, and from the USB Cable.
2. Next I want you to connect the 2 USB connections that go to the computer ( one says Power, one says Power and Data) to the Back of your computer.
3. Finally I want you to connect the Mini USB connection to the One Touch Drive.
I have seen this work in many instances.
If this works email me at, mattaitken_14@hotmail.com
Posted on Sep 28, 2008
    Sergeant:
  • 300 Answers
1. make sure all your USB ports are enabled in the bios and have an IRQ normaly 11
2. download and install all windows critical updates and service packs
USB 2.0 enabled by installing windows XP service pack 2
Applicable to all XP operating systems.
If all else failes USE YOUR WARRENTY if the drive is still under warrenty.
Posted on Sep 11, 2008
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
Can't access Maxtor Manager on 250GB Maxtor Basics portable USB
ANY WAY I WOULD JUST LIKE TO KNOW WHY U WANT TO USE MAXTOR MANAGER..
IF U JUST WANT TO WORK WITH THE HARD DISK U CAN GO TO DISKMANAGEMENT AND INTIALIZE THE HARD DISK AND IT WORKS NORMAL IF U NEED THE MAXTOR MANAGER JUST TRY TO FIND THE APPROPRIATE ONE FRO THERE SITE WHICH MATCHES YOUR HARD DRIVE MODEL.
GOOD LUCK
Jan 01, 2009 | Computers & Internet
My maxtor wont work at all
It could be a couple things - do you still have the Maxtor software installed on the PC? If not you may need to reinstall the software because it may be a password protection issue.
If that is not the case the drive could be damaged. If damaged you may or may not be able to recover the data. Try downloading a product I have used before from Easeus (http://www.easeus.com/). Its drive recovery software and may locate the drive when Windows cannot.
If that does not work you may need a professional to repair the drive or recover the data.
Dec 09, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor mini iii 120 gb HD
Uninstall the back up software, and choose another or reinstall it.
Oct 17, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
