SOURCE: oil change on my 1990 fzr yamaha 1000
20/50 shouold be fine oil drain plug is under the belly pan
SOURCE: My Yamaha FZR 1000 Genesis clutch is leaking fluid
Sounds like you need to replace a gasket.
SOURCE: 1987 yamaha fzr 1000. lights get brighter when i raise the rpm's.
Check the charging rate of your bike, if the lights are getting brighter on acceleration thn its prolly over charging!
The rectifier could be the culprit.
Good luck.
knight . ( Yamaha Sca XJ750A 1981)
SOURCE: spark plug number
The stock plug for your bike is NGK- DP8EA-9
A “very helpful” rating on this answer? Thanks! < And it doesn’t cost anything extra!
SOURCE: yamaha fzr 1000 exup 1990, bike's been standing
this happens after they sit a while, get her started, get her rolling, put her in second gear, hold the clutch in, get her up to 20 miles an hour, hold a little throttle on and slam on the rear brake, this usually will free up the stuck friction plates. If not try it a couple of times, it has always worked for me, also if that does not work for you you have to take the side cover off of the engine (clutch side) and using a flat headed screwdriver, and a zip tie to hold the clutch lever back to the handle bar, place the screwdriver in between the clutch plates and gently pry them apart from each other, on your bike I believe you have 7 friction plates and 6 steel plates. ( if you have to remove the cover go get a gasket first).
