Question about V, Inc. Vizio P4 Plasma Television
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
We have had this TV since we bought it at Costco years ago. It has worked fine, until about 5 minutes ago. TRUE, the remote stopped working years ago (and that was a big disappointment), so we have turned it "on & off" at the TV button, as well as volume adjust there too (the channels worked through digital cable remote, but that remote won't work for "on-off" or "volume'). So, for years, as I have said, the TV is turned on at switch. My wife went to turn it on (as usual) a few minutes ago, and nothing happened. None of the 4-5 switches seem to work now. So, TV won't turn on at all. Any suggestions?
P. Gregory (Greg) Frey
  • gony Oct 11, 2008
    I have the same problem. It just doesn't turn on. It make a little poof from the speakers.
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Posted on Oct 04, 2008
2 Suggested Answers
  • 2326 Answers
SOURCE: You have been assigned to my problem with my Vizio P4
I opened the chat but could not type anything to respond to you.
You can let write to premium.experts@fixya.com and ask for a refund or not to be charge for the chat that could not be established.
The failure with your TV could be a power supply but in order to know that for sure, the voltages will need to be measured. This procedure will require you to open the back cover of the plasma and to know how to use a voltmeter.
This type of repair might not be a DIY because of the danger of electrical shock when working with high voltages.
Let me know if you require further assistance.
Posted on Sep 08, 2008
I have a Vizio TV 27" LCD LED. It is 3 motnth old, bought from COSTCO. Couple of days ago the sound is not there any more. No Audio. Just a noise. I can control the volume ( of the noise ), but I...
The manufacturer usually have a year warranty on their equipment. Look through your info and contact the company. Let them know that the audio decoder in the TV has failed and that you request further action on their part. Make sure you have your receipt handy. Oh, you did register it right? if not do that now with the info you have on when you bought it. (lots of times it doesn't matter if you register it late or not so-long as you have proof of purchase)
Mar 28, 2011 | Vizio VW42LF 42 in. LCD HDTV
Vizio screen goes black
It's possible that your sustainers are going bad. These are the two boards that goes vertically on both sides of the TV.
Jun 06, 2009 | V, Inc. Vizio P4 Plasma Television
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Vizio VX37L 37'' LCD HDTV Television not turning on
Unplug set and hold and press the power button for about a minute. Replug set and turn it on. If nada, then the issue is with the power supply of the set. Given its age and the high cost of repairs it might be more cost effective to get a new set.
May 03, 2017 | Vizio L37 Television
Screen went black on Vizio 42" plasma TV
The cost to repair it might not be a worry, parts for those types of sets are not available, the plasma style sets are replaced by LCD/LED.
Oct 14, 2017 | V, Inc. Vizio P4 Plasma Television
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Pop of Death
Having the same problem except on a 32 inch LCD
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
VIZIO BLACK SCREEN
That problem is the Ysus board, Sometimes people will replace the Zboard at the same time. If you bought it at costco a couple of years ago you are in luck costco will refund your purchase price, costco has changed the return policy and newer tv's are not refunded, but something to look into
Jun 06, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
V, Inc. Vizio P4 Plasma Television Logo
694 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
