Question about Sport & Outdoor - Others
Wont start I have a 2006 HD sportster 1200XL - the first time I turned on the key lights came on - tried to start engine - did not start and all power went dead - turned key on/off no power returned - just got a new battery last week - what should I check?
The key light means your alarm shut the system down
Posted on Oct 10, 2009
    New Friend:
  • 182 Answers
Check the connections on your battery
Posted on Sep 22, 2008
2006 1200 portster new battery new starter wont start or turn over
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Jan 06, 2014 | 2000 Harley Davidson FLSTC Heritage...
Red key light stays on and bike wont start 1200XL sportster
Hi Anonymous, you might try an alarm overide for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Aug 14, 2013 | Harley Davidson Motorcycles
2007 Harley Davidson 1200XL Custom Sportster- brake light stays on all the time Trouble shooting hasn't helped. Any Advise?
Brake switch is stuck in closed position.
Or get yourself a schematic, examine the brake light connection to the power line and you will see the possible causes of the anomaly. Or a wire that is always hot when ignition is on has managed to touch your brake hot line thus leaving the light on all the time that the ignition is in the "on" position.
May 01, 2017 | Motorcycles
I have a 1200xl c custom sportster and i have forward controls but the oil feed pipe will not fit, is there a special pipe for this, i have bought the normal one from hd but as i say it wont fit due to the...
I can't tell you for sure since I don't have a parts book. But, if you told the dealer exactly what model Sporty you have, he should have ordered the correct part. I'd take it back.
Good Luck
Steve
Sep 06, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
93 HD Sportster 1200 will not start!
Have you tried to bypass the starter button/switch? Use a heavy jumper wire to go between the starter terminal and the positive battery terminal. Turn the key to "On" position, make sure "Run/Off" switch is turn on. Make sure bike is in neutral. I've started guys bikes with coat hangers before when they lost had trouble with the starter button. If the bike starter turns over, you'll at least have a place to start looking for the issue. Also you said you checked the battery, what was the voltage?
Jun 02, 2010 | 2001 Harley Davidson XL Sportster 883...
Fuel leaking
sounds like the float is stuck open
Mar 27, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
Bike is not getting any fuel to stay running
fuel inj. when you turn the key on you should hear the fuel pump turn on and pressurize the system for 4 sec. if not check fuse
Dec 20, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Engine won't turn over
Sounds like a dead battery to me. Hook it up to a good charger not a battery tender.
Apr 18, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
2006 HD Sportster 1200XL rear cylinder not working
Sounds like an ignition problem. Probably a fowled or damaged spark plug or lose or damaged spark plug lead. Try new spark plugs, I only recommend NGK and you may need to fit hotter plugs for cold weather riding. Plugs are cheap and thats the best place to start.
Dec 16, 2008 | 2006 Harley Davidson XL 1200 R Sporster...
Sport & Outdoor - Others Logo
123 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
