Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
PIP-Picture in Picture
We lost our manual and need some guidance on how to use the PIP feature
Please help
Posted on Sep 28, 2008
Vizio picture in picture
you can use the remote controller or the menu button in the tv panel. and then go to channel mode set up, select the PIP option.
Sep 15, 2012 | Televison & Video
Picture-in-picture won't go away
Does this happen with TV signal only, or with other inputs as well?
Jul 10, 2008 | Sony KV-27V22 TV
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
How do i get the pip, Picture in picture to work ??
If it has the feature buttons on the remote for it, swap, position etc.
Some older sets have to have signal routed to one of the rear video inputs for a source for the PIP. Newer sets have two tuners--one for main and one for PIP---if pulled up the swap will switch one picture for the other--some allow both on the screen at same time side by side.
Read the owner manual to see if the set has PIP.
Jun 12, 2012 | RCA P52960 52" Rear Projection Television
Does this Sony Model KV-DR29M69 have the (pip) feature?
yes here is the link for your owners manual
http://www.sonydigital-link.com/tv/crt/crt.aspx?site=odw_en_GB&m=KV-DR29M69
Dec 18, 2009 | Sony KV-DR29M69 29" TV
How to work a sony 40 in projection tv's picture in picture feature
Locate PiP button on TV remote and press it to turn on picture in picture function and again press the same button will turn off PiP feature.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Televison & Video
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
PIP DOES NOT CANCEL FROM LARGE SCREEN.
your cable or dish box may have a pip function.
Jun 02, 2009 | Sony BRAVIA KDL-46V3000 Television
TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Changing channels on pip feature
I THINK YOU HAVE TO TRY TO SOLVE THE PROBLEM WITH THE REMOTE CONTROLLER SHOULD BE  FIND A KEY FOR
USE PIP
Dec 06, 2007 | Televison & Video
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
