Question about Sony KP-51WS500 51" Rear Projection Television
Sony kp51 ws convergence problem
I've tried the flash and convergence manually but the colors are still separate and not even coming close with manual adjust.  is there a way to fix this myself, since it's not worth paying a huge fix it bill. thanks. Jill
  • burchr80 Oct 06, 2008
    I have the same problem. Tried convergence menu but I cant get blue and red to line up with green completely in all areas. The corners are especially off-centered. I tried opening up the back of the TV, cleaning the tube lenses, and looking for the supposed STK 392 560 but was unable to locate it. This TV has had no problems for over 4 years until just now.
    Genius:
  • 2,920 Answers
You need a new convergence board
Posted on Nov 04, 2008
My picture is awful! lines don't seem to converge even when I try to do it manually. Everything is doubled. Can't even read the score when there is a basketbal game on! Any ideas or help would be...
Ur tv is 100% have a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Colors are separated red, yellow and green so picture is blurred
lgray1010,
Try using the Flash Focus to/or manually try to dial in the convergence. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure on between $250.00 and $400.00 USD.
-Chris
Aug 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
In your On Screen Display menu (OSD), you should have a place that says "convergence". As a sub heading to this it will say "Auto-Convergence". This is where you want to be! Hit OK under AUTO, and watch the magic happen! If your set happens NOT to have AUTO, you'll have to do it manually. You're going to make the lines all match up doing one color at a time until all three colors are done! It's not hard at all. It may take a little patience at first, but just think of all the money your saving by not having a TV tech come out to your house and you'll be fine!
May 31, 2009 | Mitsubishi WS-55807 TV
All of a sudden our color has gone crazy on our 54" mitsubishi. They look bleeding and when there are words you see two almost as if it is 3D what do you think?
If you look closely and the 3 colors are separated, the problem is in the convergence circuit. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages inside the set even when unplugged. If you wish to attempt the repair yourself, let me know and I'll provide additional details and instructions.
Dan
Feb 17, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Model Sony 61HS30
no, if touch focus didnt correct it, you will need to replace the convergence ICs
Mar 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
178 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
