Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Round filter door with little hole
How do i get that silly door open?
  • 205 Answers
There is a small hole in the door, you need a small drill bit or maybe a large paper clip to push in the "lock" behind the hole while you push the lock in turn the door clockwise and the door will come off. Try a rattling motion as it's not a smooth easy turn. Then get you wet vac, and a towel or two, turn ithe vac on and loosen the cap, a turn or two, on the pump, depending on the size of your vac you may have to stop and empty it a time or two. When you have all the water out take the cap out the rest of the way and collect your prize. line up the inner piece with the slot and replace the cap. Good luck, chuckb
Posted on Mar 15, 2009
Door will not unlock
There's a small round "door" at the lower front right of the washer. At the 5-o'clock position in the door there is a small hole. Put a small screwdriver blade in the hole and push in just a little then rotate the door clockwise up to the 6-o'clock position. The door will come out and behind it are the drain filter and the emergency door unlocking rod/cable held to the right side of the drain pump by a clip. Gently pull the rod/cable down until a click is heard then open the door.
Jul 20, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to open little white door
Welcome to FixYa.
Hopefully the info below will supply you with the answer you requested and a little more.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges on the lip of the panel are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan )
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
May 16, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you open the round service door?
Hi biskra, I see this question was posted almost a month ago however, it doesn't appear an answer has been presented so let me...better late than never hopefully. To open the service door ( this is the small round panel to the lower right of your main wash door on Bosch WFMC washers, for those not familiar ) you will need a small screwdriver or a drill bit or anything small enough to fit in the small hole you'll see in this panel. Once you've located the hole, apply a little pressure inward ( theres a lock tab there ) and turn it clockwise and it should come right off. Once off be careful, the edges are extremely sharp. Hope that answers your question. If so please rate it accordingly, if not let me know how I can assist you further. Thank's for visiting "fixya" for your solution and good luck. Macmarkus :)
Mar 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
What can i do if my washer won't open?
**Please shut off your breaker at the service panel before attempting to perform any service I suggest to you **
On you washer you`ll see a small round plastic door on the right hand side near the bottom. This door can be opened with a small screwdriver (you should see a tiny hole in this cover) insert the driver it into the turn-hole and twist/turn counter-clockwise. Be careful, the edges are very sharp once this little door/cover comes off.
Once removed you`ll first see the drain pump, you might want to unscrew the insert/filter to drain the unit now if there is water present in the basket. You can reach in and there will be a manual release pull string, it should be attached to the pump, but if not feel around. Pull it and the door will release.
Hope you found my solution helpful. If so, please take a second and rate the solution you received from me here at fixya.
Good luck
macmarkus :)
Dec 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My bosch 1200 classixx WAE24164GB will not spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Pl rate me 'very helpful' for the free help, thnks!
Oct 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Rear pass. door locking mechanism
I just had the same problem. Can you still hear the electric power lock operating and clicking? If yes, it's easy to fix. Get the window down, so you can se the actuator motor through the gap and most likely the metal arm which connects to the lock felt just about half an inch down through the actuators connection. There is a little round hole at the end of the actuator where the arm is supposed to go through. The arm operating the lock is running just below the motor all the way through the door. This happens a lot when the silly plastic connection to the inside door button felt apart and got lost (AMERICAN MADE ...haha). The inside button doesn't operate anymore and the little steel arm is hanging free and is only connected to the actuator motor's arm through a little whole with some rubber. With enough vibration and door slamming it might eventually become loose and fall down, leaving the actuator working but not connected to the lock... Now, just get an old coat hanger, bend the wire like a hook and pull the arm below the actuator towards the front. The door will be unlocked. Now loosen the screws on the door handle and remove the clip on frame around the inside handle. Then carefully pull out the door panel starting at the bottom, then the sides (it's a little hard to get out - be careful not to brake the plastic parts). Once it's loose, push it upwards - it's sitting on the window frame. You can access everything easily now and reconnect the arm through the hole at the end of the actuator. Secure it with some cable binder around the top if you want - if the little connection knob on top of the steel arm is wrapped in a cable binder, it won't fall down again. Check if it works, put it back together, DONE!
Apr 27, 2009 | 1999 GMC Suburban
Freezer door pops open when refrigerator door is closed and water is gathering under vegetable drawers.
Well the water gathering is probably the drain hole plugged,(under bottom drawer),its a round plug that sticks up a little,it turns out like a bolt,--now about the freezer door,how is the door seal?bad as in warped,torn,bent?incase you didnt know there is a magnet inside the seal.also check if the door needs to be re-adjusted
Apr 21, 2009 | Refrigerators
Bosch Calssixx 1000 Express Washin Machine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Pl rate me 'very helpful' for the free help, thanks!
Sep 08, 2008 | Bosch Classixx WFL 2066 Front Load Washer
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
111 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
