Question about Duracraft DB101 Floor / Box Fan
Fan blade broken
I need a fan blade for a window fan model 50
Fan has broken blades. need to replace blade assembly. Where can I get one?
THEY ARE NOT UNIVERSAL! Is it the blade or blade holder? What make/model of fan do you have? You need to buy a whole set of whatever you need or most likely your fan will wobble.
Jul 13, 2015 | Dryers
Akai air conditioner model interior fan blades are broken'll need to remove the blower assembly to replace the cage.
Dec 15, 2013 | Heating & Cooling
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Can I buy only fan blade? My one got broken
All of the fan blades are one piece along with the hub which is attached directly to the motor pulley (if fan is like the fan which is pictured).
This is true even if there is some kind of attachment between each blade and the hub -- it comes as one piece.
If you can purchase it, or another which will function like it, there are two places you may go to: 1) Sears sells parts for everything they sale. If you didn't get your fan from Sears, then you can still go to Sears and possibly locate a fan which is close enough. 2) Appliance parts stores (like A&M Parts/Johnstone supply) sell fan blades.
Before you begin, remove the broken fan blade (including hub). Matching the diameter and pitch of the blade and the hub to motor attachment is the goal. It can only be of good to know the make and model, but it is not necessary.
Jun 04, 2011 | Lakewood 16" Stand Fan
Broken barrel fan
I am not familiar with the Blueway brand but have never seen an air conditioner on which you could not replace the fan.
Is this a split system or a window unit? If a window unit it may not be worth the trouble.
Jan 29, 2009 | Heating & Cooling
Broken blade and missing glass on Harbor Breeze 52'' Aero
Home depot or lowes. bring old parts an match them up. most fan parts are available for H.B. fans
Dec 10, 2008 | Electrical Supplies
Broken fan blade
go to ur nearest electrical shop and tell them the model and the brand name buy that and fix it but you wont be getting a sigle blade you ll get the blades in a set not as single you need to remove all other blades and fix the new blades
Jul 22, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Fan blade for a U2-20
I have a metal blade for the Patton U2-20 fan listed on ebay. The item number is 160273949463 and the listing ends on Wednesday August 27 at 10.00 p.m. I had this fan for 8 years and the motor has failed. Patton could not replace the motor since this is a discontinued item, and I figured that someone could use another blade for their fan. I hope this helps you!
Jun 27, 2008 | Patton Electric U2-20 Box Fan
Duracraft DB101 Floor / Box Fan Logo
29 people viewed this question
Top Duracraft Dryers Experts
Bonard Allen
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
