You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
You may have a convergence problem. Here are some of the most common symptoms and example photos. Screen looks 3D
Colors don't line up
Screen is bowed or warped.
Solution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Need to change convergence ICs
If you need more info., let me know and I can go over the details
[email protected]
Double image, like seeing 3d without glasses, any ideals
As well as the convergence being off, the picture is in a convex shape.
On Saturday, our TV started its own 3D programing!! We have tried to adjust the convergence, but the little + won't even move. We tried everything, but nothing is helping. We watched a show, and the longer the show the worse the picture got! We had purchased the extended warranty...and now we are getting snaked by the store/ service center. Any suggestions for fixing..other than target practice!!!
sony 57' kp57ws510 57 in rear
how do you change the convergence ICs?
