Question about D-Link DI 707P (DI-707P) Router
Configure to print
How do I configure my Windows 2000 and Windows XP computers to print to the DI-704P, DI-714P+, DI-707P, DI-704UP, or DI-713P?
    Novelist:
    Scholar:
  • 123 Answers
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Posted on Feb 16, 2006
4 Suggested Answers
De Guyver
  • 123 Answers
SOURCE: configure to print
De Guyver
  • 123 Answers
De Guyver
  • 123 Answers
Please explain how to connect LinkSys D-Link wireless broadband router Model No. DI-713P with Comcast broadband modem and Dell OptiPlex 360 Desktop? I am using Windows XP-Pro. Thanks, dana
What is Comcast Modem's Model?
if your modem is not a Modem Router:
here is the link where you can download the manual...Mid left of the web page.
http://support.dlink.com/products/view.asp?productid=DI-713P
if you have Modem Router?
Bridge your Dlink router by changing the IP Address of Dlink Router and connect it wired to the LAN port.
send me your email add so that I can send the instruction How to install.
Mar 20, 2009 | D-Link DI 713p (DI-713P) Wireless Router
Vista Compatibility with DI-704P
The print server software does not need to be installed in order to print to the printer attached to the 704P from Vista. I went out to D-LINK's website and there are step-by-step instructions for configuring port 192.168.0.1 and associating a printer with that port.
See the following link:
http://support.dlink.com/faq/print.asp?productid=794
These instructions are for 2000/XP but they are very similiar to what you need to do for Windows Vista. I tried it and it worked fine. It did take me several tries however, as I should have read through the steps completely first.
May 29, 2008 | D-Link DI-704P Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Can´t print through the router print server
Try changing the Spool Data Format setting in the printers control panel from EMS to RAW. Step 1 Go to Start>Settings>Printers. Step 2 Right click your printer icon and select Properties Step 3 From the properties screen, select the Details tab. Click on the Spool Settings button at the bottom of the window. Step 4 From the Spool data format: select RAW from the drop-down menu. Click OK to close out of Spool Settings and OK again to close out of the printer properties screen. Close the Printers control panel and try printing to the DI-713P with these new settings. In some cases, you may need to disable bidirectional printing.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Configure to print
Feb 16, 2006 | D-Link DI-704UP - 4-Port Broadband Router...
Configure to print
Feb 16, 2006 | D-Link DI 713p Router (nwl-di-713p-r)
Configure to print
Feb 16, 2006 | D-Link DI-704P Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Online web configuration
For the DI-704P (Revision B) you will need to download and install the Java Plug-in for your Operating System. To download and install the Java Plug in now click the link below. Windows XP, Me, NT, 2000, 98, or 95 and Internet Explorer - http://java.com/en/download/index.jsp An alternative is to upgrade your browser to the following: Internet Explorer 5.5 or higher (with SP1) Internet Explorer 5.x (Mac) Netscape 6.0 or higher Mozilla 1.2.1 (5.0) or higher Firefox 0.8 or higher Opera 6.0 or higher Safari (with Java 1.3.1 or higher) Camino 0.7 or higher
D-Link DI 707P (DI-707P) Router Logo
166 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
