Machine won't turn on when I push the button
The machine will not turn on when I push the start button. It's a digital mashine about four years old. I live in Medellin, Colombia and I don't have an instruction manual. Is their a reset button or built in circuit breaker or something? If not, where do I start looking for the problem. All the repairshops here are thieves so please help me figure this out.
Thanks,
Ron Graham
  • 4 Answers
I had the same problem with a Fisher & Paykel Smartdrive 701. First try disconnecting power lead for 5 mins, then plug back in and try again. It sometimes resets itself. Second try is the fuse. Take off the control panel cover (2 screws), open the blue control box (the larger one still mounted in the machine) and you'll see a simple fuse. If you're lucky this is a very cheap fix and hopefully didn't blow for a reason.
If the fuse is OK then it will be the main circuit board blown in the smaller blue box that comes off with the control panel. F&P don't sell component parts for these like a simple blown micro-switch, and a new board is $200+ labour to fit.(5 mins)
Great washing machine but my boards only last 4 years between replacements. Have now bought their new Aquasmart machine.
Good luck.
Eddie.
Posted on Sep 15, 2008
Can't get my machine to start after programme has finished
I find quite often I have to turn it anticlockwise for it to allow me to start it again, or wait for a short while (my plug is behind the machine)
Mar 31, 2014 | Russell Hobbs RH1042 Frontload Washing...
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
Single mother of four wash machine not working only 2 yrs old.
Take off electricity wire, Open the filter from the front( maybee need to remove a rectangular cover.) turn the filter anti-clockwise. take out the hairneedle or coin. (the water will come out from the filter so make preparation with towels., see inside the filter if something is stucked around the small propellar. Turn the electricity back on. choose for example pumping program or centrifugeprogram. After that the machine should work.
Jun 01, 2013 | Whirlpool Washing Machines
My singer quantum xl-150 won't sew at all.
Of course needs oil u might have ******** it up.Try oil.
Aug 12, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
I turn on the mashine programme wool and turned it on but my little one pressed the buttons after it and now there is a key on the display, the button "Start" is flashing but when I press it it...
Your machine has (quite correctly) operated it's child safety lock.
Your manual should tell you how to re-set it, however, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and you should be able to start the program again as you would normally
Jul 19, 2011 | Washing Machines
Whirlpool wont go in to spin turned machine to
might be a bad lid switch or the couple between the motor and trans could be broken
Feb 27, 2010 | Whirlpool Washing Machines
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Washing machine will not run
main control board has expired-replace it
May 03, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
452 people viewed this question
Top Washing Machines Experts
