Rowenta DW9080 Iron with Auto Shutoff Logo
A
Anonymous Posted on Aug 22, 2011
How to clean - Rowenta DW9080 Iron with Auto Shutoff
Anonymous
Level 3:
  • Rowenta Master 43,501 Answers
  • Posted on Aug 22, 2011
Anonymous
Rowenta Master
Level 3:
Answers
43501
Questions
0
Helped
10835329
Points
101584
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
There is no cleaning button on my new iron to clean the tank. On my last iron I would hold it down to clean hard water particles.. nothing on my new iron.
Since the new iron does not have a cleaning button, use distilled water only. Also, cleaning with a mild vinegar solution will help keep it in good shape. Just be sure and rinse the solution out.
Jan 02, 2019 • Irons
1helpful
How can I clean the ceramic sole plate of my iron
Follow These Steps
  1. Mix water and baking soda. Make a paste of 1 tablespoon water and 2 tablespoons baking soda.
  2. Apply the paste to the iron. ...
  3. Wipe iron clean. ...
  4. Clean steam holes. ...
  5. Re-fill the reservoir. ...
  6. Turn on the steam. ...
  7. Pour out the liquid.
How to Clean an Iron Video and Steps - Real Simple
https://www.realsimple.com/home-organizing/cleaning/laundry/clean-iron How can clean the ceramic sole plate of my iron Google Search
Oct 26, 2017 • Irons
Leaking water around base
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
I have just fitted a new solanoid to our steam generator pro express iron. Previously it would continously steam and the answer given was that the solanoid was sticking in on position. now the red light to...
If the iron does not spray properly, inspect and clean the nozzle (see below).
However clean very well the surface of solenoid, and see if there are something abnormla in the surface and clean it. and test it again. tight very well the connection of solenoid, can be loose and produce NOT strong attraction.
God bless you
Nov 12, 2012 • Irons
Tefal Gv8110 Steam Generator Iron no Steam
follow this steps. God bless you
Nov 10, 2012 • Irons
How do you clean the soleplate? I have some residue/buildup that does not wipe off. I already did the self-clean to remove deposits but there is still "stuff" on the soleplate
You can use Rowenta Sole plate Cleaner. If you cannot find it locally, check online at retail sites like Amazon.
If you want to try a home made cleaner, Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
If this does not work, then you will need to heat a solution of white vinegar and salt until the salt dissolves. Using a clean cloth sipped in the heated solution, wipe the iron's soleplate clean. Continue wiping until you have removed all of the build up or corrosion. Remember to wipe the iron completely clean with a cloth dampened in clean water.
Let me know if you have any other questions. Thanks.
Read more: http://www.doityourself.com/stry/cleaniron#ixzz1L4J0N8Yh
1helpful
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
8helpful
2answers
Sensixx cosmo - how do I drain & clean this
Go to wallmart, they sell steam iron cleaning either solution or powder. It is not too dear.
Aug 03, 2009 • Irons
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
