What cables do i need? - Televison & Video
  • 70 Answers
Depends on tv for hd tv either hdmi or component regular tv but newer either compmonent or s-video older tv yellow red and white very old tv rf modulator with coax
Posted on Sep 21, 2008
How do I connect the parking break cable to the spring on the rear caliper? is there a special tool
What you need to do is get as much slack in the cable as possible. The E-brake is on a self-adjusting reel which winds the cable as the lining gets thinner. Watch finger tips.as you need to release a spring loaded tang to let cable roll out of reel. Sometimes you need to pull cable beneath drivers door area to unspool the cable.
When you return to the rear of the car check where the cable fastens to the rear brake mechanism. The fixture may need to be pushed into the brake backing plate.
Sometimes you need to twist the brake shoe onto the cable and THEN pin the shoe to the backing plate.
Oct 27, 2013 | 1994 Mercury Sable
Why would speedometer needle bounce
The needle bounce may be related to the cable, it may be broken or just needs lube.
Remove the speedometer cable, locate the connection at the transmission and unscrew it, then locate the connection at the rear of the speedometer, remove the cable from the car, pull cable out of plastic housing and see if it comes out in two parts, if it does then cable needs replacing.
You will see the cable has two ends, is the cable is broke replace it, a broken cable will sometimes spin and not spin causing needle to jump, also a binding cable will do the same, if cable is good then spray wd40 in to cable and spin by hand. note; if cable is binding you will need to work it so it does not break. good day
Apr 29, 2012 | 1984 Toyota Celica Supra
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
Mar 01, 2011 | Computers & Internet
My rxv667 picks up a sports chanel on all inputs the hdmi av and even when i have the tunner set to a music station
Bad cable, bad ground, poor connections are the likely culprits. Make sure all your connection cables are good quality (doesn't mean you need to go bankrupt buying Monster cable, but really cheap cables can be an issue), that the connections are tight. Make sure polarized plugs are in the socket properly. Any really long cables? Those do need to be the highest quality you can afford. Neaten up your cables, keep audio cables away from power cables (if they need to cross, cross at right angles), keep speaker cables away from audio cables.
Possibly the receiver is defective, but I would check the cables and check them again and do that a third time.
Feb 06, 2011 | Yamaha RXV667 Receiver
I don't have cable but in order have the wireless cable do i need to have cable installed first?
Yes you certainly need a cable connection before you can use the wireless capabilities of the cable modem.
Without a cable connection the modem is useless.
Regards.
Sep 30, 2009 | RCA DCW615R Wireless/Cable Modem
I need an extention cable for a tv. Please direct
Your nearest Radio Shack should be able to help you out.
Sep 07, 2009 | Televison & Video
How do I make my tv hd
Hello Kathy, you will have to contact your cable or satellite provider. You will have to obtain a set top box with the ability to output an HD signal. You will also need an HDMI (High Definition Multimedia Interface) cable or a set of Component cables (Red, Blue + Green). The HDMI cable transfers the audio and video through the one cable, the Component cable is just for video. You will need different cable for the audio, there are a few different ways to do it. If your cable TV provider does not provide you with the cables you need, I would suggest checking out monoprice.com for the cables you need. They carry high quality cables at very inexpensive prices, your just paying for the name with the other name brand cables out there.
Enjoy your HD experience
Mar 02, 2009 | Hitachi 51F59 51" HDTV Projection...
HT-X50
You need an Optical Audio1.gif Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System1.gif. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 24, 2007 | Samsung HT-X50 System
Need help finding replacement monitor cable
what color are the ends of the cables, blue you need a vga cable, white a DVI cable- there are two types of dvi cables look at the connector if it has a plus sign in it you need a dual link otherwise a single.
Oct 26, 2007 | ViewSonic G790 19" CRT Monitor
Televison & Video Logo
Top Televison & Video Experts
