Question about RCA B27TF680 27 in. TV/VCR/DVD Combo
Ant/cable hole on back of set looks broken
Can look in hole and see copper coils. cannot figure out how to connect tv ant
  • frog16 Sep 18, 2008
    Tech 57, thank you for your suggestion.  I spoke with a TV repair company in my area.  He said he would have to remove the back off the TV and replace the broken off connector.  He said it would take about 1 1/2 hours to do the work.  I haven't done anything because the set is too large for any one person to carry.  I was wondering if some sort of box could be attached to a different port that would have an available antenna connection.  Frog16
Connect a VCR or DVR, with a built in tuner, using the video and audio inputs. That would be the most reasonable solution, other that purchasing a separate tuner box, whic would be to costly.
Posted on Sep 18, 2008
  • 28 Answers
You are going have to soldered a new coax connector into the tuner, which is not an easy thing to do. It would be a lot easier just to replace the tuner. Check with Andrews Electronics, and get someone knowlegeable in electronics to help you with the soldering.
Television was alright when it was cut off. Next morning cut it on and the picture is all yellow and blue.
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
Jun 10, 2011 | Sansui DTV3200 32" TV
How to program with cable using remote
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
Where do i connect the analog cable to?
Just connected to the Ant. hole in ur LCD tv,just like u would of connected to an Analog tv set.
May 06, 2010 | Insignia LCDTV26 26 in. Television
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Cannot connect to cable tv
Yes, connect cable to Ant A and ensure the TV is on the input for Ant A.
Then go into the setup menu and ensure that the Input is set to Cable not Antenna.
Next, choose the auto program option to load your channels.
If you still don't get a picture and you have a small tv to bring to this outlet try this and make sure you are able to get a picture.
If you still can not get a picture then the outlet is not active and you need to call your service provider and ask them to activate the outlet for you.
Dec 29, 2009 | Mitsubishi VS-55707 TV
Broken Antenna Port
If you have already identified where the connection was on the board you will have to access the board to be able to solder back to the points where the old connector was. Once you have identified the two solder points (One should go to ground and the other if you can with the tv on touch it and see if a picture tries to come in or get rid of the snow). Then buy a matching transformer from radio shack or Home Depot, Lowes. Normally this would go on the outside antenna. But you want to take it and clip and strip the ends that have the forks. Solder this to the board, one to ground and the other to the point that would have been center on the old broken piece. This will have a 72 ohm or a connection that your antenna will connect to.
Jan 11, 2009 | Toshiba TP50G60 50" Rear Projection...
VCR/DVD
Hi and welcome to FixYa,
Initially, it would appear that the only INPUT possible is through the RF connector. Should this be the case, a workaround would be to connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Emerson TC1325 13" TV
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
Using a VCR with it.
Hi, Based on your post/description, a common installation/connection would be: 1. Ant/Cable in to the RF INput of the VCR (this is assuming that your cable TV is cable/F output and not the audio/video RCA output); 2. A short RG59 cable with F connectors at both ends should connect RF OUT of VCR to ANT/CABLE IN of TV. 3. With the VCR off, the cable would connect automatically to the TV and channel selection is thru your TV. 4. With the VCR on, The TV must be set to either 3 or 4, channel selection may be done on the VCR, TV programs can be recorded, video tapes can be played. A variation: Another would be to use the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV (assuming it's got one). The TV must be set to Video to watch cable, VCR. Channel selection would be thru the VCR. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 09, 2007 | RCA F25216BC 25" TV
RCA B27TF680 27 in. TV/VCR/DVD Combo Logo
120 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
