Question about Microwave Ovens
Kenmore Microwave Model 665.61652100
Our microwave seems to be heating not as well as it did 2-3 weeks ago. We took the front panel off and found that the 20 amp fuse seemed to be blackened. We replaced the fuse tonight, but it does not seem to have solved the problem. To test, we popped a bag of popcorn using the popcorn button prior to replacing the fuse and after. Both times, it took an additional 2-3 minutes to pop the bag after using the popcorn button. Additionally, we tested a regular cup of tap water. Usually it takes 1:35 to heat the cup of liquid to be HOT. Now it is taking anywhere from 3-4 minutes to make that happen. Does anyone have any suggestions for how to fix this problem? Are there other components that I should look at?
  • Microwave Ovens Master
  • 9,098 Answers
The fuse will either be good or bad. If it blows, the unit will be "dead".
Assuming electrical outlet voltage is low, I would suspect that your magnetron is failing.
The magnetron usually has a warranty of 5-9 years.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
Posted on Sep 09, 2008
How to wire the transformer and capacitor and magnatron in a kenmore 665.61632100 microwave
and you want what us to do the job you started . I was trained to make a drawing of what I took off . so I had it for reference when putting back . but that was 50 + years back
Oct 21, 2015 | Kenmore Microwave Ovens
Where is fuse located on a microwave
YOU MAY HAVE TO TAKE OFF THE BACK OF THE MICROWAVE TO FIND THE FUSE. YOU MAY ALSO BE ABLE TO LOOK UP ON LINE WITH THE MODLE NUMBER TO GET A MANUAL THAT WILL TELL YOU WHERE IT IS LOCATED.
Feb 02, 2015 | Kenmore Microwave Ovens
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Microwave 63301 - Power, but front panel doesn't operate
You have a failed membrane keypad or the problem may be on the board itself.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in most cases in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodesmag-glass_10x10.gif, and capacitor
Oct 28, 2008 | Kenmore 62622 Microwave Oven
Kenmore 62622 (model) -microwave-loud noise -no heating
dis-assemble waveguide and clean thoroughly. try again. if no-go then failed magnetron. get new unit.
Jun 08, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
