Question about Dometic RM2652 Refrigerator
Dometic RM2652 or RM2852 not working.
Just bought my first RV(used) and the fridge does not work.It has power and also gas.The on/off light comes on and also the auto light functions normal.The check light even lights after a few minutes when there is no gas.The unit just does not cool at all.Checked fuses and all good.ANy suggestions?
  • 2 more comments
  • bonjomatassa Sep 08, 2008
    unplug the refrigerator for 1 hour then plug unit back in.
    Should Work.......Gook Luck...........jo
  • Anonymous May 25, 2009
    When I started by RV refrigerator for the first time this season, I turned on the auto button, and the frig began operating but with gas even though plugged into electricity. Electrical did not kick in at all. Checked fuses and and plug ins, but they are okay. I turned off the gas to see if electrical would kick in and ignitor wanted to light.
  • durango7 Jul 25, 2010
    same refrig RM2652. will not get cold on ac . turned to gas i can see a small flam. won;t get cold, and i think i can smell ammonia smell.???????????
  • Anonymous Mar 17, 2014
    I have a Dometic RM1350 MX fridge in my 5th wheel trailer. When you turn on the fridge it will go on for about 1 minute then give an E0 error. I have checked the connections at the back of the fridge and on the eyebrow piece above the fridge. All connections are tight. This error is the same whether I try to run the fridge on gas or auto. The E0 error means that the control board is not getting communications from the eyebrow.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
Posted on Sep 30, 2008
  • Ron J fox Jun 14, 2012
    Thanks Robert I'll let you know how I make out your thr bestest Ron F
  • 51 Answers
Hopefully it is only a heating element. Supply gas and see if it holds flame if it does it should heat the coils all the way across. If it does not your coil is most likely bad. Is there any yellow powder any where on the back or inside if so also a sign of a bad coil.
Posted on Sep 08, 2008
  • Ken Bellringer Sep 08, 2008
    When you test it on gas it will take a while before you feel the coils hot to the left of the burn chamber for the unit to get to full temp is 24 hrs
Fridge check light is on and fridge not cooling
disconnect thermistor on back board let run if ok replace if not bad board or cooling unit
Apr 02, 2013 | Dometic RM2852 Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Aug 08, 2009 | Dometic Refrigerators
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
May 10, 2009 | Dometic RM2652 Refrigerator
Refrigerator not working
LOWER CIRCUIT BOARD
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
equipment.
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
VERSION I
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
VERSION II
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
VERSION Ill
Display Panel 2932189.03
Power Module 2931842.04
Oct 03, 2008 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
1,034 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
