Question about Alpine CDA-9885 CD Player
CDA 9885 No idea why it suddenly stopped working
Hey there,
About 1 year ago i got my CDA - 9885 installed at JB hifi along with my 2 amps, 6" splits and 6" speakers with my 12" kicker sub.
Now everything has worked fantastic for the last year, then yesterday for no reason this happened:
It just cut out and turned off, so i turned it on again and it went to radio then it played fine, i switched to cd player then it just keeps turning off again, (now sometimes it will play the cd without sound and sometimes it says "ERROR" or "EJECT" and sometimes it wont even play radio with sound.
and even sometimes it plays the cd fine with sound but it will only last like 10 seconds?
Now i have not touched anything it has been working great for the last year. also i have checked all the fuses.
Now my question is could my Amplifier running to my Sub actually cause my head deck to turn off? as it may be that that amplifier is temperamental.
any help is needed as im sure its not a wiring problem.
thanks heaps :)
MIke
    Master:
  • 413 Answers
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Posted on Dec 29, 2008
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
My Alpine 9885 stops outputting sound to everything but the amp (and therefore sub). Turning off the deck and then powering back on seems to fix it temporarily. Any ideas what could cause this?
You have a speaker with an intermittent problem or a speaker wire shorting out. The unit has a protection circuit so it doesn't fry the amp inside
May 14, 2010 | Alpine CDA-9885 CD Player
Alpine CDA-9885 intermittent problems
you can try removing the faceplate and cleaning the copper contacts with a pencil eraser. This might help
Jun 15, 2009 | Alpine CDA-9885 CD Player
How do you hook an ipod up to the CDA-9885 Alpine sterio?
Hello billybob3491,
The best way would be to add the Alpine optional proprietary iPod connection cable. This will give you full control of the iPod from the radio. Your CDA-9885 uses the KCE-422i optional cable.
The cheapest way (with lower quality audio) would be to use a generic FM modulator with a mini-jack input. The Scosche FMMOD01 shown here is sold in numerous stores from $17 - $50. Another downside with this method is that you have no control of the iPod from your head unit. But, hey! It works.
Hope this helps.
May 04, 2009 | Alpine CDA-9885 CD Player
Alpine cda 9885 Poor radion reception
Your antenna wire could be loose behind the radio because sometime they will have to use an adapter because of the size another thing could be if you have a sirius/xm radio they will send you an adapter to cut down on the static for free also the adapter on the sirius could be loose or bad good luck
Dec 30, 2008 | Alpine CDA-9885 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Cda 9883 and cda 9885 2008 model no song issues
My ipods fuction fine with my Alpine CDA-9885 ... have you tried pressing the display button on the Alpine? The KCE-422i cable takes quite a beating ... You might check the cables.
Feb 14, 2008 | Alpine CDA-9883 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
Alpine CDA-9885 CD Player Logo
175 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
