Question about Belkin Tunebase FM with ClearScan for All iPods with Bonus USB Sync/Charge Cable, Auxiliary-in Cable... (F8Z959-CC)
Useless? Hi, I only got my clearscan a few months ago and while trying to adjust it, it fell apart in my adaptor. I have 3 items: a springy thing, an empty tiny tube, and a little cap. Can I fix it? Thanks, Jess
  • jack209 Oct 18, 2008
    i have the same problem but have lost the spring and contact shaft.can I get parts? model #f8z049-blk. thanks ja
I had the same problem... but I only have the hollow tube(fuse) a cap, a bolt, a washer, and the plastic safety thing-a-majig
Posted on Jun 06, 2009
I had the same thing happen, only I seem to have lost the springy part so I can't put mine back together. Any idea of where I could get a replacement part. I've only had this item for a little over a month.
Posted on Sep 22, 2008
The washing machine will start turn a few times add some water but then stops and the light flashes
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Mar 23, 2014 | Amana NFW7300WW Washer
Simpson sears canada
this is fixya site and we have nothing to do with the product or the manufacturer
kindly address your dissatisfaction directly to the manufacturer
Jun 28, 2017 | Food Mixers
3 months a ago my entire hub and break assembly fell off with rear rihgt tire while bieng hoisted up to be repaired at the shop. It has only been 3 months and already i am having same symptoms as before...
Hi, how in the world did it just "fall off"? Did the mechanics tell you what caused it or which part was faulty? What exactly are the symptoms you are experiencing? Thanks, Mike
Jun 14, 2011 | 2004 Kia Sedona
Pump fell apart - inner piece fell out
On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
Jan 05, 2010 | Cycling
Advent adaptors are unreliable
Every Advent product I have ever bought has been rubbish in some way or another. The Advent Powerline plugs are with out doubt the most unreliable pieces of **** I have ever used. I must have been through about 4 of these things now, and they just keep going wrong. Usually they just stop working one day and never come back on. Well done PC World for bringing this 'excellent' product to the wide audiences. My advise, stay clear of this and every Advent branded product you can. Spend a little bit more and you won't regret it.
Jun 05, 2009 | Computers & Internet
Freezing
hi
please follow below steps :-
1- disk cleanup in C drive. right click on C: drive and click on properties and click on disk cleanup button.
2- type TEMP in run command and delete all file in open windows.
type in %temp% in run command and delete all files in open windows
3- try to download superantispyware and smitfraudfix.exe for delete infected files.
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
http://siri.urz.free.fr/Fix/SmitfraudFix.exe
disable unwanted startup items from the MSCONFIG
type MSCONFIG in run command.
click on startup items then disable unwanted programs
Thanks
veeru_india
May 08, 2009 | Dell Inspiron 1501 Notebook
Oven just died on me!
The same thing just happened to ours which is just one year new. Waiting to hear if anyone can offer suggestions/feedback.
Mar 23, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Car Adaptor
just odered a cord yesterday from Todd and its on its way by UPS
Aug 25, 2008 | Disney D7500PDD Portable DVD Player
My camera broke!
Ok I haven't tried this yet because my camera is at home, but I have the same problem mentioned. I contacted a sony tech online and here is the conversation. I hope this works!SONY: Please try resetting the Camera.To reset the Camera, remove the battery pack from the Camera and then press and hold the POWER BUTTON of the Camera for 30 seconds and then reinsert the battery pack after 1 minute and check if the Camera works normally.K:Ok- So what if this doesn't work?I'm at work now and my camera is at home, I plan on trying it when I get backSONY: After performing the above steps, please press the MENU button on the Camera to check whether you are able to access the MENU items on the Camera. If you are able to access the menu items on the Camera, please try initializing the Camera. Please perform the below mentioned steps to initialize the Camera. First, please press the MENU button to display the Menu screen in the Camera.Using the Control buttons, please select SETUP menu. Then, in the SETUP menu, please select SETUP 1 menu. Now, please select INITIALIZE option under the SETUP 1 menu of the Camera and set it to OK.K: Great thanks! So what happens if I can't access the menu?SONY: After removing and re-inserting the battery, the issue should be resolved and you must be able to access the MENU items on the Camera. If the issue still doesn't resolve, please feel free to contact us.
Nov 03, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Belkin Tunebase FM with ClearScan for All iPods with Bonus USB Sync/Charge Cable, Auxiliary-in Cable... (F8Z959-CC) Logo
329 people viewed this question
Top Belkin Audio Players & Recorders Experts
ocgordy
Level 1 Expert
woodzowl307
Renee Knafel-Bullock
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
