Question about ASUS A8V Motherboard
Case connector problem
Want to connect the mic and speaker connections of the front of the case to the mobo.  don't know which ones to connect to.
    Brigadier General:
  • 5,158 Answers
We would need to know the motherboard you have. most i've worked on have a 7 or 8 pin connector near the bottom of the motherboard.... next to the pci slots. if that front devices uses a modular plug it usually has a blank pin slot so you cannot hook it up to say a usb port.
Get out your magnafying glass and a light... the connectors are often labeled right on the board.
Please rate this solution.. thanks
Posted on Sep 08, 2008
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for...
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Sep 03, 2010 | ASUS Computers & Internet
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on
Feb 08, 2009 | Intel Motherboard
Installing mobo
Mar 01, 2017 | Computers & Internet
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
Apr 23, 2008 | Intel Motherboard
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
ASUS A8V Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
