SR1010V wont power up
My moms electric went out last week and when it came back on, her pc wont boot up. the power light blinks rapidly but nothing happens when you hit the power button. i am wonderign if there is a reset button or an easy fix before i take it in to the repair shop. i have worked on pc's before so can do "some" stuff but haven't a clue on this one...
thanks,
jag
  • 5,568 Answers
Have you already tried pulling the AC plug for an hour or two? Power failures may leave some bits and pieces of software kind of laying around and interfering with the boot sequence.
Check to see if the fan is turning (and staying) on when you plug back in and try to power up. If not, then a replacement supply may be due.
I'm pasting a note I just pasted elsewhere about this.
"Since there have been some changes in available outputs and connectors even on ATX supplies, make sure you compare pictures of the supply to your own but in any case, I would recommend using a replacment rated at 350W as this will run more conservatively and not be as stressed as the 250 you now have. It won't cost a lot more and will not consume any more power but the critical components will run cooler.
Not as a recommendation, just a current example on eBay:
http://cgi.ebay.com/Mustang-Switching-Power-Supply-350W-Model-LC-B350ATX_W0QQitemZ250294363195QQcmdZViewItem?hash=item250294363195&_trkparms=72:1156|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
  The last couple I bought were $5 each with $7 shipping charge from a US source."
Posted on Sep 19, 2008
Toshiba L745 laptop will not boot up. Get black screen and the hdd light is blinking. Cooling fan speeds up and slows down. Don't get any activity on it at all. Was working last time I used it about a week...
Unplug the power and take the battery out. plug it back in after 5 min then turn it on. see if you can see a faint image in the background. the LCD backlight could of went out.
Sep 11, 2013 | Toshiba Computers & Internet
I have an hp compaq 6720s and my charge port light blinks rapidly, it wont let me charge my battery and the computer wont turn on when the battery is full any thoughts?
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Mar 24, 2011 | HP Compaq 6720s Notebook
I can not start my PC. It does have a green
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Oct 01, 2009 | HP Pavilion Media Center a1330n - AMD...
Compaq presario sr1010v power light blinking
Try disconnecting the A/C source.
Allow unit to set for 5 minutes.
Re-install power and restart uint.
If that does not work, Disconnect power and remover supply connections at the motherboard.
Allow to set for afew minutes, and re-connect.
Sometime, removing the connections at the motherboard, allows the supply to reset.
You should have a 4 pin video connection and a 24 pin main board connection.
Note. Make sure your power is disconnected before attempting this service.
Sep 29, 2009 | HP Compaq Presario SR1010V (568656) PC...
Power light blinking
if the power just shuts off for no reason when booted up,it may be the power source is on the way out ,it will work for a while, but keeps crashing, thats the first thing to replace
also make sure you hear the fans working
if it overheats it has a safty shutoff ,
you can also use a house fan, aimed inside the computer while open, to rule out power source
Jul 21, 2009 | Dell OptiPlex 170L PC Desktop
Trouble starting and blinking dash
I had exactly the same problem this morning after returning from the store. I replaced the OEM battery with an Optima Red Top Model 25. Problem gone. Chrysler OEM batteries rarely last more than three years. You don't need to buy an Optima, but they do last a long time.
Good luck....
May 11, 2009 | 2006 Chrysler Town & Country
My desktop PC is a Gateway GT5656. The power
Could be try putting your power LED on your HDD LED header on your mainboard and then look at this while booting up and this will tell you if its the LED or the Header on your mainboard
May 03, 2009 | Gateway GT5654 Desktop PC
Computer wont turn on
Could be your power supply or cord.
Mar 12, 2009 | Computers & Internet
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My pc is not turning on (all the light does is blink orange)
Woops -the blinking amber light of doom is a common fault on dells -
usually a solid amber is the Power supply while a blinking one indicates Motherboard problems. If machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
Dec 07, 2008 | Dell Dimension E520 PC Desktop
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
