Question about Lexmark Office Equipment & Supplies
When I try to Make a copy Lexmark X 83 begins to shake and rattle, then makes a terrible clanging sound and the while machine is jumping!! What can I do???
  • Lexmark Master
  • 6,487 Answers
This is a problem with some parts of the copier, I belive you can still print abd scan with this mulitfunction printer, so what's the best thing that you can do here is to check if there any foreign object that got inside the the unit and also check the parts if still propelry conencted to each other a assembly guide will be helpful for you...
Hope that helps.......
Posted on Sep 08, 2008
    Brigadier General:
  • 5,158 Answers
Have you done anything recently to the printer such as add a new cartidge ?
Robert
  • Roberta Smith
    Roberta Smith Sep 08, 2008
    also check for a paper jam
    Robert
  • Lexmark Master
  • 19,396 Answers
Check if the ink carrage is mooving freely on the rail, it looks like a mechanic problem.
  • Ginko
    Ginko Sep 08, 2008
    Check if there is any foreign object inside the machine , like a small screw. Eventually turn machine upside down and shake it a bit.
    Check if the ink carriage can moove feely on the rail, try to understand if it is the carriage stuck that make noise.
    Problems of this kind are caused by mechanic faults, usually, if you do not find the problem with a general inspection, a technician must take the printer apart and assemble it back after finding the problem.
    Check if something is obstructing the carriage, or the paper.
    If the motor is making noise and not running you may need to replace it
When spinning washing machine jumps a bit and makes a rattling noise as if something is loose in machine.
may need to balance machine on floor and or check the shocks, the balance springs, the counter weights or suspension rods, etc and or the motor coupler
Jun 08, 2015 | Washing Machines
GE washer makes clanging sound during wash cycle
What is the model number of the unit?
Nov 02, 2012 | Washing Machines
Makes a terrible clanking when I turn it on.
Deb, unplug the saw and open the covers that allow full access to the top and bottom big wheels. Slowly turn the bottom big wheel by hand to see if you can determine what it banging. Perhaps the blade is very loose. This is tightened by turning a handwheel probably located on the very top of the saw. Knowing how tight to make this is pretty much by trial and error, but if you can easily deflect the blade (half-way between the wheels) by 1/4 inch, then it's too loose. If a loose blade is not the problem, remove the blade (wear gloves) and see if both the upper and lower wheels move OK without banging. From there, it depends on what you find!
Good luck,
Sep 15, 2012 | Ryobi Saws
My 2000 Subaru Outback has a loud rattle from the rear gate (ie door)
Check your rear stabilizer bar an make sure that all the bolts are still intact. You may also want to crawl under the vehicle and give your muffler a shake to ensure that no mounts are missing. these are the most common issues associated with rattling from the rear of vehicle.
Apr 18, 2012 | 2000 Subaru Outback
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
I have a 2005 Dodge 1500 with a 5.7 Hemi. when I start out in forward or reverse it makes a popping noise sometimes and you can feel it shaking.
Just a guess, but it sounds like the U-joint on your drive shaft could be going…With a cool vehicle of course, you should be able to lay under the vehicle and physically grab the drive shaft and turn it back and forth and hear a clang or feel the looseness etc…You won’t hear the pop till the torque is applied...It’s not an expensive job, of terribly difficult to repair yourself…tg
Mar 15, 2010 | Dodge Ram 1500 Cars & Trucks
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fridge makes an odd rattling or woodpecker like sound intermittently. What could this be? Thanks.
If you have an icemaker, that would be the sound of either the mechanism emptying the cubes or the water valve shutting off. If the water valve is going bad, or the switch that shuts off the water valve is going bad, the water valve may 'chatter'. If this is the case, try shutting off the icemaker, or even the water supply to the unit to see if it stops.
If you don't have an icemaker, then the circulation fan may be rattling a bit or has something in it, like a bit of paper. Circulation fans are typically behind a panel in the freezer sectionon most models.
Some units rattle the metal cooling pipes a bit when the compressor motor starts up. This is a more metallic clanging sound.
If it's a very sharp repeated clicking noise, that may be the sound of the motor-start capacitor going bad.
Oct 07, 2009 | Hotpoint Refrigerators
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
