Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Bell south internet
Why does it take so long to connect to bell south internet?
Once I finaly get connected, the speed is fine
    Problem Solver:
  • 5 Answers
Sounds like a dial out problem. Talk with your local telphone service and try getting a service call to check your line.
Posted on Sep 30, 2008
Speed up download & up loading on iPad mini 4
You can't speed up the device only the internet connection. My internet connection also supplies my television signal from Bell so I have 125mbps. It is blisteringly fast. The device you have is only held back by the size of the 'pipe' that the date travels down. Your iPad Mini is plenty fast enough, your internet connection isn't.
Upload a file from home and time it. Upload the same file from MacDonalds when the place is EMPTY and time it. The place must be quiet as you are all sharing the same connection.
Dec 25, 2016 | iPad mini Tablets & eReaders
Why do Netflix movies keep stopping?
It could possibly be a slow internet connection speed. Netflix posted requirements. This is a good site to check your speed. Internet Connection Speed Recommendations Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
HD Video Quality
Movies and TV shows we have available in high definition will play in 720p or better with a fast enough internet connection. To watch Netflix in HD, ensure you have a HD plan, then set your video quality setting to High in the Playback Settings for your account.
Netflix Bandwidth Usage
Higher quality video uses more bandwidth than lower-quality video. If your service provider applies a bandwidth or data cap to your Internet service, you canManage Bandwidth Usage by changing the video quality settings to Low or Medium to consume less data.
Oct 01, 2014 | Netflix
Can not get connection to the internet with my MOTOTOLA WN 825G
at the command prompt (dos black screen) type ipconfig /renew this should reset your local ip address for the new Bell router. Your laptop is trying to use the settings from the old router.
Sep 01, 2009 | Motorola 802.11g Wireless Notebook...
Downloadspeed is low
to accelerate both download/upload speed delete all temp files and make clear cache everyday finaly test ur speed im sure would be faster.find here ur speed
Mar 21, 2009 | Computers & Internet
How to speed up my net
Here you go;
Windows XP change DNS server
You can Click on Start button > Settings > Network connections
Double click on Local Area Connection or your Internet connection
Click on Properties button
Select Internet Protocol (TCP/IP)
Click on Properties button and Look for Preferred DNS Server:
Setup NS1 -
Setup NS2 -
Save and close the windows. If you are using old version of windows you may need to reboot the system.
To test new setting go to Start > Run > Type cmd
Type nslookup command
Now type domain name
Linux change DNS server
Please read following tnstructions:
If you are using a Linux, you can further increase speed by installing squid local proxy server and dns dnsmasq caching server.
For more information, see their website
Good Luck
Please rate
Jan 20, 2009 | Microsoft Windows XP Home Edition
The internet is sometimes slow and the fan inside keeps speeding up and going really fast
if u wanna increase your net speed first you have to delet temp files in your system, and another is do not open multi screen at a time..these two reasona are down your internet speed mostly..and finaly check your internet speed with after doing both actions what i written above..
Jan 12, 2009 | Computers & Internet
Belkin router with a laptop
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
Nov 08, 2008 | Computers & Internet
Suddenly lost internet connection on 2Wire DSL modem
hmmm...only thing that makes sense here is that your dSL is unhappy...did you check that phone line into the modem? that's what the internet light means when it's out, actually..if its not the line, then it's the modem..
not much else that is off on this.
check your computer warranty here 4 FREE
Feb 28, 2008 | Computers & Internet
Bell South Telephone Manual, Model 222 (20 Memory)
I have this phone...once I find the instruction book I can help you if you still need it.
Feb 28, 2008 | BellSouth Lands Phones
Slow WEB with Netopia 3347W
don't worry, there is a major fault in the cable , cable in the mediterranean is damaged and the international gateway is not opening, it will take few more days to set it right, then speed will be fine
Feb 04, 2008 | Computers & Internet
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
108 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
