Question about Dryers
Kenmore 110.72982102 running only when I hold start switch, but still don't heat up.
Buffalo12980
  • 625 Answers
SOURCE: Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Posted on Sep 22, 2007
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
Maytag317
  • 1136 Answers
SOURCE: kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Posted on Jun 28, 2009
cooper0365
  • 347 Answers
SOURCE: My Kenmore Elite 63952 have to hold down start.
yes switch is bad u will see on very back of machine they are a acess panel on very top of the back may 6 to 8 screws take them out remove acess panel off then un plug the the switch u should see how to remove the switch......make sur u un plug the machine before taking it apart
Posted on Oct 23, 2009
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
TUMBLE AND HEAT IS O.K. SOMETIMES STOPS WAY BEFORE TIMER EXPIRES
motor over heat you may notice you have to hold the start switch long and motor has a hard time starting. often while running sounds like alot of vibration
Aug 01, 2010 | Kenmore Dryers
Kenmore Elite electric dryer, no heat, runs if holding start ****
with this combination of problems it sounds like a power problem on the control board being you have more than one problem,it sounds as though you arn't getting a latch voltage at the relay energizing coils that latch the relays to power the motor and element
Apr 16, 2010 | Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Dryer start button
The motor switch is not switching over. Either the switch is bad or the dryer is not tumbling fast enough to activate it. Eric
Aug 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Must hold start button to run. no heat
Dec 30, 2008 | Kenmore Dryers
Dryer shuts off when releasing start button. Will run while pressing down start button, but no heat is generated. Sears repair man wanted to replace Even Heat Control Board for $350. I bought the part...
replace the motor, as you are holding in the start button you are making the dryer run in the start winding of the motor, it is designed to only stay in this winding untill the centrifigual switch on the motor automaticaily switches it to the run winding, when the motor switch knows that it is using the run winding it closes the motor switch contact for the heater to come on, replace the motor
Apr 12, 2008 | Kenmore 63942 Dryer
Sep 21, 2007 | Dryers
Dryers Logo
142 people viewed this question
Top Dryers Experts
