Question about HTC S620 Smartphone
HTC Dash The green status light on the top center of my phone never turns off, not even when the power is off. How can I change that?
  • 3 Answers
Solid green means battery is fully charged
top LED flashing green means connected to your network ie bt ,o2 ,
BOTTOM LED flashing connected wi fi network
Posted on Sep 15, 2008
  • varley2130 Sep 15, 2008
    hope this helps
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
I recently replace the battery in my 2005 Ford Mustang GT. After I installed the new battery the green light for my dealer installed alarm keeps flashing even when I am driving the car. I went to the...
                Hi
                Before Battery Change
                • When was/or when did you notice alarm green light illuminated?
                • When after alarm was disarmed, did green light shine?
                First thing to check would be electrical connections starting from the battery.
                1. Follow positive wire lead from battery to fuse box connections. (Should be along driver side frame rail, or near battery.)
                2. Follow wrie harness to Relay Center. (Find Alarm Relay/Fuse)
                3. Also to Power Distribution Center. (upper driver corner engine bay)
                Relay Switch and Fuse to Alarm should be okay, given the alarm green light illumination.
                The Cars Brain, ECM Engine Control Module, manages messeges between power BattV and Alarm, also other modules and various sensors throughout the vehicle.
                When Battery Supply was disconnected, something happened, that stunned the memory in the ECM.
                Yes, the alarm does need resetting, its actually the memory messages saved in ECM need to be Refreshed.
                (saying "alarm needs resetting") sounds like alarm is broken, when that is not the case. Similar scenario is, when smart phone screen webpage freezes(alarm memory info in ECU). No buttons work, not even power button (Key Fob control). Only way to gain access is to remove battery.
                Lets try an experiment, this will be to loose still/saved frozen information, stuck in computer memory.
                How to Reset Vehicle Computer.
                1. Remove Neggative Post connection.
                2. Remove Positive Post connection.
                3. Let vehicle sit over Two Minutes, this time allows capacitors in vehicle Modules (ECM/PCM, TCM), to release any/all stored voltage, also any voltage in Vehicles ground circuit will be released.
                  • (I would typically wait 15 minutes) Capacitors with out constant Voltage input, will disipate rather quickly, depending on capacity size.
                4. With Battery Still Disconnected. Open Driver Car door, and turn Ignition to RUN Position.
                5. Reconnect Positive Post.
                6. Reconnect Negative Post.
                  • IGNITION is in RUN Position, when reconnecting Battery. Driver Door Is Open.
                  7. Turn Ignition to Off.
                  • Notice if alarm green light is illuminated.
                  8. Hit LOCK Button On Driver Door Switch to Reinitialize Alarm.
                  • Be SURE Key Fob not locked in car.
Mar 26, 2017 | 2005 Ford Mustang
How do i pair up mu htc hd2 with htc bh m300 as i bought new one its not been showing in my device
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Oct 08, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
What does the status light mean,it's green
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
May 10, 2010 | LG Flare Cellular Phone
Hi I am having trouble with an LT180 DLP I'm getting a series of error messages culminating in the power light steady orange and the status light flashing a series of 6 flashes red. Inside I found that...
both lights flashing green indicate the projector lost power while it was running (didn't get to go through shutdown procedure). if the status light blinks 6 times, the lamp is failing to strike (one time means the cover is open, 2 times is a temperature issue, and 4 times is the fan). if it comes on and shuts off a short time later (less than 15 seconds), the ballast is going bad and needs replacing. if it didn't come on at all, it'd be either the ballast or the colorwheel. if the lamp light was red, it would be the lamp that needs replacing. nec won't sell parts to anyone who is not an authorized nec service center, so you'd need to contact one to get the part (although they may not sell it to you). but good luck!
Aug 20, 2009 | NEC LT180 DLP Projector
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Oct 08, 2007 | HTC P3300 Smartphone
HTC S620 Smartphone Logo
172 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
