Question about D-Link AirPlus DI-614+ Wireless Router
Why can´t I access the web-based configuration for my D-Link router, print server, or access point?
Posted on Oct 17, 2008
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.jsp To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?prod_id=801 Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?prod_id=1372 If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?prod_id=1053 Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
Posted on Feb 16, 2006
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
SOURCE: can´t I access the web-based configuration
SOURCE: access configuration
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.js... To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?pr... Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?pr... If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?pr... Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
SOURCE: access web configuration
Nov 23, 2010 | D-Link Wireless N 150 Home Router 4Port...
Jul 29, 2010 | Computers & Internet
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Aug 01, 2009 | D-Link DI-704P Router
May 22, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Feb 16, 2006 | D-Link DI-704P Router
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Aug 13, 2013 | D-Link AirPlus DI-614+ Wireless Router
Mar 09, 2017 | D-Link AirPlus DI-614+ Wireless Router
360 people viewed this question
