Question about Whirlpool Duet GHW9150P Front Load Washer
F 06 error code
Some days the machine (5 years old) works fine all day doing 3-5 loads a day and some days it takes up to 8 hours to finish one load!  It is very inconsistent and even when I unplug and replug it won't do a drain/spin or rinse/spin.  Do you think it may be just a loose wire being that it works fine some times.  I'd hate to spend money on a repair man if the wire just needs to be secured.
  • Kris_009 Oct 02, 2008
    Even when I ran the diagnostics, it worked 3 out of 4 times. This problem has been going on for quite a while. I tried r-eseating the connector between the motor and the MCU. Sometimes it seems to help and other times it does nothing.
  • 5,911 Answers
The "F06" error code is a Motor Speed error. The following link explains the recommended course of action you should take:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Now, another tip to try BEFORE you assume you have any failed parts is to unplug the washer for at least 30 minutes. This is recommended by the manufacturer to reset the main computer (or CCU). Sometimes this tip will reset most common system errors. If the problems persists, I would recommend checking the wiring harness between the Motor Control Unit (MCU) and the Drive Motor, followed by resistance checks of the motor windings. You may have a loose connector somewhere (as you suggested) or a component beginning to fail after it heats up (hence, the reason why the washer works for a while, then sometimes fails). Intermittent problems aren't always easy to troubleshoot. If your symptoms keep reocurring, take note of when and how (i.e., after several loads, during heavy loads, during final spin, etc.). This will give me an idea of what may be causing any repeated error codes. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 08, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
What's wrong with my amana washing machine?Takes about hour to was a load and after2 loads you must work to get it to work.Only had it 5 days.
surely warranty after 5 days. just call the people you bought it from. it could be anything, possibly the pump overheating. maybe an electronic board fault. call for service from your retailer.
Dec 08, 2014 | Amana Washing Machines
Whirlpool ultra care II quiet wash II - over the past few day has run intermittently. It stops for what appears to be no reason. Can't get it to start. I turn it off, then a few hours later when I...
Sounds like motor overheating and shutting down. Motor will have to be replaced if that's the case. Probably not feasible on a 10 year old machine
Aug 25, 2017 | Whirlpool Washing Machines
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Kenmore Oasis Elite Top Loading Washer with multiple errors
Yes - replace the ECU/Controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Error code upsidedown f and e
ok you need to reply to the recall notices as that could be causing your promblems the code you are seeing is unusal high low temptures being sensed pop me an e mail at b4829@yahoo.com
Mar 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
