Question about RCA Universal Remote Control
RCR312W Won't WORK!!!
I have the RCR312W remote and programmed it regularly. It was working, but now no matter what button I push, the ON/OFF button and CHANNELS buttons keep flashing!! What do I do??
  • sballi4 Sep 14, 2008
    i programed my remote now it wont work i would like to try to reprogram but lost the tv codes i have a memorex tv and need the codes
  • Anonymous Nov 03, 2008
    Yea i have this same problem and it is really starting to tick me off, since i have to reprogram the stupid remote like every hour, i may just go ahead and buy a completely new remote that is not rca
5 Suggested Answers
  • 8 Answers
SOURCE: i need code for zenith tv to program into rca remote #rcr312w
Hi cuddles3634!
For that remote, the tv codes are:
Zenith 1000, 1006, 1049, 1054, 1078, 1116, 1133, 1167, 1170, 1172, 1207, 1230
If the TV is digital: 1016
Hope that helps!
Posted on Jan 05, 2009
SOURCE: I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Posted on Jan 08, 2009
freetek
  • 5568 Answers
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Posted on May 17, 2009
  • 814 Answers
SOURCE: which buttons do I push to program a RCA universal remote RCR312W
Sorry it took so long to respond to your request for assistance. Youcan find the instructions and codes you need to program yourtelevision at the RCA customer support website[http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web addressand paste it into the address bar of your web browser. This will takeyou to the RCA main customer support page. Just go to the universalremote control section and find your model remote control. Use themodel number to find the technical support information page. On thispage will be a copy of the owners manual and the remote control codesto use with your products. I hope this information helps you with yourproblem of needing instructions and codes to use your remote with yourproducts. Thank you for using FixYa and have a nice day!
Posted on Jun 22, 2009
  • 547 Answers
SOURCE: cant program my remote
I could type each step in and claim it's my own brilliance, but really you should just follow the steps at wikihow (transcribed from RCA's website)
If that works for you, please be sure to rate my answer as "helpful"
Thanks!
Posted on Aug 31, 2009
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
CODE FOR RCR312W FOR MY APEX TV
Turn on the TV, Press and hold down the TV button while entering one of the four digit codes, if the ON/OFF turns off on the last digit entered, that's the correct code, if not, repeat steps, using a different code until it does..here are the codes,..1137,1141,1235.....hope this was helpful...
May 28, 2010 | RCA DIRECTV Satellite Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Universal remote no RCR312W need to program for a Sharp t.v. what is the code and what order do you use
[Sharp 1004, 1006, 1012, 1026, 1029, 1095, 1111, 1112, 1171, 1173 ] This is the listed code for Sharp televisions and your model remote control.Usually you just push the button you want to use and enter the code number. If one code number does not work go through the list until you find one that will work. If you need more assistance with the programming of your remote control, you can call the RCA customer support at this telephone number 1-800-645-4994 Give them the model number of your remote control and ask them for assistance. I hope this information helps you solve the problem you are having programming the remote control. Thank you for using FixYa and have a nice day!
Feb 20, 2009 | RCA 3-Device Universal Remote with...
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Feb 15, 2009 | RCA Universal Remote Control
1) turn on unit
Oct 17, 2008 | RCA Universal Remote Control
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
How do i program my remote
Hold button down for unit you want to program. (TV,DVD,VCR) Then hold down on off button at same time. On/off button will turn off then come back on. When this happens push the play button. Wait 10 seconds and then push again. Repeat until unit turns off. Once unit turns off push rewind button one at a time until unit turns back on then push the stop button.
Sep 29, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
122 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
