Question about HP PhotoSmart 7660 InkJet Printer
Print cartridge cradle is stuck
Says to clear jam, but have no idea?
  • merry4 Sep 22, 2008
    Gives the message "Print Cartridge Cradle is Stuck", "Clear Jam and then Press OK". But there is no paper jam. And when I turn on the printer it just makes a whirring noise.
  • 2,071 Answers
Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in.
If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Sep 08, 2008
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
I reconnected my printer and it says..''Print cartridge cradle is stuck. Clear jam and then press OK''. What do I do? Where's the cradle? I'm messing with it and I got nothing. I HAVE to print out...
>the cradle is the carriage which hold your print cartridge.
>follow the steps on this link, this should resolve your issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255616&cc=us&lc=en&dlc=en&product=397810
Sep 29, 2009 | HP Photosmart 8150 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
check the sensor , either there is somthing stucking on the sensor you cannot see it, either the sensor it self becomes bad.
Apr 17, 2009 | Office Equipment & Supplies
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7660 InkJet Printer Logo
155 people viewed this question
Ben Johnson
