Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Frost free refrigerstor
Door hard to open because of vaccum sealing
    Genius:
  • 1,122 Answers
Use a little vasaline on door gasket and it will be better
Posted on Sep 12, 2008
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
The frost free freezer has started to form ice
First point of investigation, is to check the door seal. Sometimes new seals get stuck-suction and when opened and shut possibly cause a small tear, lubricate very gently with Vaseline, this will enable the seal to firstly seal properly and secondly not put undue pressure due to suction on new door seals.
If that does not resolve it then have a technician check the thermostat.
Mar 04, 2015 | Frost Refrigerators
Excessive frost- maybe door won't close well Builds up on to shelves the worst--could it be the rubber seal
First you must fully defrost your freezer. Frost simply attracts more frost. A build up of frost large enough to prevent the door closing properly will grow very rapidly indeed and waste a lot of electricity; it will also overload the compressor and can cause it to fail prematurely.
If the seal is damaged then it will allow moist air in and cause frost. If the seal has simply become unseated, then refitting it will prevent a recurrence.
Unless you have a frost-free model, then all freezers eventually need defrosting. You can slow the process by never opening the freezer door unnecessarily and also by never leaving it open any longer than necessary. Frost free models rely on air circulation via a fan to prevent frost build up. If the fan fails, or if the freezer is overloaded and so preventing air circulation then it will still frost up.
Please take a brief moment to rate my answer.
Sep 12, 2010 | Canon PowerShot S1 IS Digital Camera
Freezer is frosting
Even frost free freezers will frost up in high humidity, especially if there is a poor door seal. Defrost the freezer by turning it of and placing pans of hot tap water in the freezer. You can speed this along by helping to remove the ice as it melts. Check the door seal after you've defrosted the freezer, a bad seal is one of the big causes of frosting up the next biggest problem is usually holding the door open.
If it's a frost free unit, if the problem continues you'll need to have it checked out.
Jun 19, 2010 | GE GSS25JEM Side by Side Refrigerator
My Kenmore freezer is continuously running. It
clean all of the door seals and all of the contact point with freezer
Jul 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Jul 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
SIDE BY SIDE FRIDGE DOORS VERY HARD TO OPEN
its because the door seals are new and are working correctly. The pressure difference between the warm outside and the cold inside cause a sort of vaccum and so makes it hard to open. It is usually only after the door has been closed a while that it will be hard to open. put your finger around the edge of the door and shift the seal slightly, this will release the vaccum and let the door open normally. It will get better after a few weeks. I have had 2 whirlpools also and this has been the same on both of mine.
Mar 18, 2008 | Refrigerators
Frost in Kenmore frost free
Although you say the seal is fine, this is almost certainly due to air getting in. With the door closed check that there isn't a tiny gap with a strip of thin card or plastic. Of course if air is getting in then it must also be getting out somewhere else so probe all around the seal.
Oct 01, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Door seal
If the door was left open you may have frozen the evaporator (on a frost free). I would suggest defrosting it as soon as possible and make sure the door doesnt get left open again. If it is not frost free it may just be that it is still trying to recover the temp it had lost by an open door. Hope this helps.
Aug 09, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
