Question about Canon PIXMA iP1600 Printer
The printer could not run...
There is an error that says "ink cartrades is not installed propely" how to fix that error sir? i intalled it properly but could'nt run...
  • ivy09 Sep 14, 2008
    a message keeps popping up stating that the ink cartridges are not properly installed. i get the same thing over and over again even when i " properly installed" it again and again. i have a canon ip1200 and bought it brand new two years ago.
  • johnnyariKI Sep 17, 2008
    I HAVENT USED IT EVEN A DAY WHEN I TRY TO PRINT I GGET AN ERROR MASSAGE SAYING CARTRIDGE NOT WELL INSTALLED I HAVE TRIED EVERYTHING, ITS NEW JUST INSTALLED ADAY AGO PRINTED FEW PAGES WITH NOPROBLEM AT ALL, YOU TURN IT ON RUNS ALL THE WAY TO THE RIGHT, NEVER COMES BAK TRY TO PRINT YOU GET THAT SAME ERROR MASSAGE '' CARTRIDGE NOT WELL INSTALLED HELP ME I WANNA BREAK THIS PRINTER 2 DAYS OLD GUYS IP 1600 MODEL
  • Canon Master
  • 4,338 Answers
Does your Alarm / Power light flash orange 7 times consecutively (ink cartridge installed incorrectly)?
Check here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11642#SupportDetailAct
Posted on Sep 29, 2008
Dear sir, though i had filled up ink into the cartirage , there is an error message E5. KINDLY INTIMATE HOW TO SOLVE PROBLEM
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly.
Jul 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What are the ways in solving an LQ-2180 when it's error in printing?
make sure the printer cable is properly connected and the driver is propely installed.
describe the problem the error.
Jan 06, 2010 | Epson LQ-2180 Matrix Printer
Printer is not print properly
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq3
Aug 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Ink system has Failed. Error: Oxc18a0306. Please Help.
what is error oxc19a0027 on an HP FotoSamrt C7280 and how do you fix it. email copiersunlimited1@yahoo.com
Oct 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
Sound problem
The message that the installation failed means the drivers did NOT install properly. Uninstall the driver FIRST before trying the installation again. Failure to remove all the sound drivers will insure a failed installation.
Sep 02, 2017 | LaCie d2 Extreme 250GB External with...
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
5100 error code
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp 160 don't work
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Canon PIXMA iP1600 Printer Logo
56 people viewed this question
old marine
old marine
