Hello!
I recently had to partly disassemble my Incanto Rondo Coffee Maker to deal with an ants nest inside the machine. Anyway, the ants are gone but now, everytime I make a coffee, the mug will be almost full of coffee even though the control panel knob is on the very left. Also, after each coffee, the alarm indicator light will go on; the same happens, if I open the steam knob and let out some water. When I switch the machine off and then on again, the alarm light goes off though.
Thanks for helping out
Tobias
SOURCE: Steam valve not closing
grandpamike im pretty sure our a guy it lot of experience in coffee machine you probably already know that but maybe in our city the water very hard . maybe you have calcium in water valve a couple of descaling maybe the solution take care grandpamike cheers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
SOURCE: Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
/Mirran
SOURCE: Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
SOURCE: Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
