Question about Motorola Talkabout 25-Mile, 22-Channel FRS/GMRS 2-Way Radios (Pair)
Motorola Talkabout 2 way radio model T9500
I have 2 radios the one radio will not recieve the message but will put out a message. I tried different settings, even making sure everything was set exactly the same. They did work when I first bought them a month ago, only used them a couple of times to test them. Thanks
  • 1 more comment
  • the91sicknez Dec 20, 2008
    i am having the same exact problem
  • elkropp Jan 01, 2009
    Same problem. Everything else seems to be working fine, all buttons, etc.. 1 will send and can be heard on the other. 1 will beep when PTT is released as its supposed to, but can not be heard on other end.
  • Anonymous Jan 04, 2009
    t9500 from motorola wont transmit
    one radio will but the other one seem's locked cant change the setting at all on one of the two can someone help me
  • Motorola Master
  • 1,654 Answers
You might check your Qt filter to see if it is turned off. You can find the instructions on page 2 of the user manual.
http://www.hitechwireless.com/pdf/T9500RManual.pdf
Posted on Sep 08, 2008
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
I can send but not receive messages on my Motorola Talkabout MH Series Two-Way Radio.
Check your CODE aka interference code eliminator. Both radios must have the same frequency and code to communicate.
Here is a link to the user guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/MH%20Series%20User%20Guide%20USA%2011-26-08%20KEM-PK14190-75.pdf
Best regards
Nov 20, 2012 | Motorola Talkabout® T9500 Two Way Radio
T5700 and T9500 con speak between them?
Directions for programming the T5700 can be found starting on page 18 here http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Directions for programming the T9500 can be found on page 1 under the heading MENU OPTIONS here http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
These two radios have many similar features, but some which differ. For best results leave all the special features such as Qt filter, call alert, and interference eliminator codes, turned off or set to zero until you get the radios to function in a basic mode on just the same channel as one another. Then once you've found what works, you can experiment adding special features, if desired.
Best regards.
Jun 18, 2012 | Motorola Talkabout T5700 (22 Channels)...
I have talkabout t9500. When i push ptt, the radio close and open. I can't transmit for this reason...
It is possible you have a battery problem. Recharge or replace your battery and see if the problem persists. Another test, you can exchange the battery with a known good radio and see if the problem is solved.
Best regards.
Aug 18, 2011 | Motorola Talkabout® T9500 Two Way Radio
I am from argentina, i have a problem in one radio motorola T9500. No receive (one second received 1 meter distance) but transmit any problem. A "tecnhical man" say me, I need load codes in the...
Have you tried receiving with a EARPHONE? The speakers in these units are VERY poor and do fail easily.
IF the earphone works(!) try a external SPEAKER/MIKE instead of trying to find and install a replacement speaker!
See the link below!
$8.99 US
Anthony
Speaker Microphone for Motorola talkabout T5022 T9500 T280 T270 T5800...
Dec 01, 2017 | Motorola Talkabout® T9500 Two Way Radio
Can recieve calls but cannot call out
Here is a link to the user guide for the T9500: http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
Check your interference eliminator code. Sounds like you have yours set to zero (off) and the other radio has it set to a number other than zero. The instructions are in the upper right corner of page one.
Best regards.
Nov 17, 2010 | Motorola Talkabout® T9500 Two Way Radio
How can I restart motorola talkabout T9500?? I can 'call' just from one radio to another,cant get two way connection..
Check your Frequency, Code and Qt filter to be certain they match identically. If this doesn't seem to work, go back to a basic operation by shutting off the Qt filter and Code. You can do this by setting them to OFF or zero. Lastly, read about Call Tones, and shut them off if you or the other user are not familar with the procedure to Transmit using them.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
Best regards.
Feb 06, 2010 | Motorola Talkabout® T9500 Two Way Radio
Hi. Looking for instruction manual Motorola T9500 2 way radio. Can you help? Thanks.
Here is the url from where you can download the manual
http://portablemedia.manualsonline.com/manuals/mfg/motorola/t9500.html
Dec 16, 2009 | Motorola Talkabout® T9500 Two Way Radio
Motorola Talkabout 25-Mile, 22-Channel FRS/GMRS 2-Way Radios (Pair) Logo
864 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
