Question about Philips Magnavox TP3285C 32" TV
Dark Spots on screen
Hi, we have a Magnavox HD LCD, having cleaned the screen with only soap and water, we have huge black spots. These seem to be getting larger. Has the screen been damaged or is there a solution to be had?
Thank you
  • Philips Master
  • 508 Answers
Black spots on LCD - if these affect the picture, then it's an impurity, although LCD TVs don't require degaussing the same way a set with a tube does. It's all electronically controlled via the inverter board and backlighting. I'd say it's an inverter/backlighting issue - which will require a service centre to replace it; it cannot be repaired at component level.
Posted on Feb 23, 2011
I might be missing something here, did you use white as you font color? Or, is there simply no answer here? As I understand a solution is a possible "fix" to a problem, I see nothing which resembles that here.
Posted on Nov 24, 2008
Posted on Nov 23, 2008
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Black spots on the screen
I think you should try going to the store and checking if your monitor is still under warrenty. From the description, I think it is beyond repair.
Jun 26, 2009 | Samsung Computers & Internet
I have what looks like water spots on inside of my lcd monitor how can i get the monitor open
You can't. Don't try. Are you sure the spots are not on the surface?
Clean your monitor screen with a soft rag and water only. If that doesn't work. you might try a solution of VERY MILD soap, like dish soap. And a very dilute solution. Wipe carefully. Never use glass-cleaning solutions like Windex or equivalent.
Mar 30, 2009 | Acer Aspire 5050-3242 Notebook
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Spots on screen
Youlikely have dust inside the optical block on the LCD panels. Cleaning the panels is a tricky job and just shooting compressed air into the block will only redistribute the dust. A qualified tech can disassemle the block and clean the panels
Aug 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Philips Magnavox TP3285C 32" TV Logo
612 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
