Question about D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b)
WAN settings How do I configure the WAN settings on my VDI-604 or VDI-624?
    Novelist:
    Scholar:
  • 123 Answers
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Posted on Feb 16, 2006
SOURCE:
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How do I upgrade the firmware on my VDI-604 or VDI-624?
Step 1 Download the latest firmware. Click here to download the latest firmware for the VDI-604 - http://support.dlink.com/products/view.asp?productid=VDI-604#firm Click here to download the latest firmware for the VDI-624 - http://support.dlink.com/products/view.asp?productid=VDI-624#firm Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click on the Tools tab at the top and then click Firmware on the left side. Step 5 Click Browse and navigate to the .bin file you downloaded in Step 1. Select the file and then click Open. Step 6 Click Apply. It may take a up to 30 seconds for the firmware upgrade to complete. Step 7 When prompted click Continue. The firmware upgrade is now completed. Step 8 If you get a Page cannot be displayed or similar error after clicking Continue, close the web browser and re-open it. Repeat Step 2 to login to the web-based configuration.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
WAN settings
How do I open a range of ports on my VDI-604 or VDI-624 using firewall rules?
Step 1 You will need the IP address of the computer that you want to open ports to. How do I find the IP address of my computer? Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click the Advanced tab at the top and then click Firewall on the left. Step 5 Select Enabled and configure the following: Name - Enter a name to identify the rule Action - Select Allow Source Interface - Select WAN Source IP Range Start - Enter an IP address or * to allow this rule to apply to all incoming IP addresses. If you are opening this rule to a series of IP addresses, enter the first IP address in the range. Source IP Range End - If you are opening this rule to a series of IP addresses, enter the last IP address in the range. Destination Interface - Select LAN Destination IP Range Start - Enter the IP address that you obtained in Step 1 Protocol - Select the protocol (TCP, UDP, or Both) Port Range - Enter the starting and ending ports that you want to open Schedule - Select Always to apply this rule all the time or Schedule to specify a schedule Step 6 Click Apply and then click Continue to apply the new rule.
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Factory default
Parental control
The following types of parental control can be configured on the VDI-604/VDI-624: Domain Blocking URL Blocking -------------------------------------------------------------------------------- Domain Blocking Domain Blocking will allow/deny access to certain websites. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select Domain Blocking. Step 5 Below Domain Blocking, select Allow users to access all domains except "Blocked Domains" to only allow to all websites except those listed or select Deny users to access all domains except "Permitted Domains" to only allow access to the websites listed. Step 6 Enter the website (i.e. disney.com) below the option you selected in Step 5 and then click Apply. -------------------------------------------------------------------------------- URL Blocking URL Blocking will prohibit access to websites than contain certain words. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select URL Blocking. Step 5 Below URL Blocking, select Enabled, enter the word, and then click Apply.
D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b) Logo
235 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
