Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Water not spraying all around,
By glenninch on Sep 08, 2008
Water not spraying all around, low water pressure.
Same Problem
Dec 23, 2008
-   Bottom arm is working, top arm has water spraying out but it not spinning dishes in top rack do not get clean, hw do I fix this?-   cobbold
Solution #1
posted on Sep 08, 2008
Somewhat Helpful)
SFroese
Rank: Guru
Rating: 85%, 84 votes
Make sure the tap is fully open. Check the water line for kinks. Finally, turn off the water and see if you can remove the water line. If so, inspect the water inlet area and see if you can find the filter/strainer. It may be clogged with debris.See if you can verify that the solenoid valve is opening fully.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
How do you turn on the water tap on the ADG64?
Answer
flashing lights on electrolux dishwasher and wont run. Tried turning off electricity breaker for a... (More)
Answer
just moved into a house has a dishwasher kenmore model 363 1411691 and the water won't drain
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , PA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
